Resultat 1 till 11 av 11
    Fredric Andersson
    Finspång
    Passat B9 2023
    Testmula för B9
    https://www.carscoops.com/2022/02/vw...t-models-body/
    VW’s Next Passat For Europe Spotted Trying To Fit In Current Model’s Body
    The Passat might be dead in the US but Volkswagen is developing a new generation for the European market codenamed B9. Our spy photographers caught the first mule of the upcoming model wearing a Passat Alltrack body.
    The test car is fitting with the body of the current Passat, trying to hide its bigger footprint. An extension between the side doors reveals that the new generation will have a longer wheelbase while our sources also suggest that it will be slightly wider as well, for more passenger room and luggage space.
    The next generation of the Passat, which will share its underpinnings with the next Skoda Superb, is rumored to be offered as a wagon only – in regular and Alltrack trims – with a potential addition of a liftback later on. This means that the traditional four-door sedan bodystyle will likely end with the current generation.
    VW Group’s upcoming wagon models will sit on an updated version of the current MQB platform, as the last ICE-powered models of their kind before migrating to electric-only powertrains. Reports suggest that the engine range will include both TSI (petrol) and TDI (diesel) units with mild-hybrid tech for lower emissions, while high-end variants will get a plug-in hybrid powertrain.
    The current Passat was introduced in 2014 and received a facelift in 2019 which makes 2023 a nice time for the new generation. Both the ninth-generation VW Passat and the fourth-generation Skoda Superb will be produced in Bratislava, Slovakia.
    Namn:  VW-Passat-Mule-7.jpg
Visningar: 1349
Storlek:  559.7 KB
    Mex
    Gillar inte listen mellan dörrarna!!!
    Håller med, usch vad fult det var. Ser ju ut som om man inte fått till det riktigt.
    aug 2017
    Johan
    Stockhohlm
    Haha! Det är en mula!
    Den kommer självklart inte se ut så där!
    Dom har ”klätt” en B9 med en B8.
    Listen är en anpassning för att den mindre karossen ska passa på det nya större chassit enligt texten. Alltså för mulan...
    aug 2017
    Johan
    Stockhohlm
    100:- på att det är fotat i Norrland.
    Mex
    Puh...!
    Fredric Andersson
    Finspång
    I skarp version men något kamouflerad.
    https://teknikensvarld.expressen.se/...visar-upp-sig/
    Namn:  70DB1D7E-E6AA-4759-B586-1C75BD2F6948.jpeg
Visningar: 1198
Storlek:  222.6 KB
    aug 2017
    Johan
    Stockhohlm
    Tänk att så stora hjul kan se så små ut.
    Ser ju ut som om den är rejält överlastad också.
    aug 2014
    Robert Lagerquist
    VAGGERYD
    Sista bilden saknar ju skarven. Påminner om en V90....
