2022-08-31, 20:25 #1
- Claes
- 5513
- Mark
- 17
Felmeddelande vid byte av skivor belägg bak Tiguan 18
Har problem med handbroms mm efter bytet ,gjorde allt efter Ross-techs guide.Även om allt inte stämde på deras video(dom kör gammal (15) version i videon.)jag har 22
Får detta vid körning
Sunday,28,August,2022,15:00:31:47336
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.3.1.4 (x64) HEX-NET2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVGZZZ5NZJW326615 License Plate: YPW686G
Mileage: 37798 Repair Order:
Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.CLB
Control Module Part Number: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component and/or Version: ESC H25 0513
Software Coding: 0AEE6B9A54222372477D070162C84950D62AC4E2E046927D38 425078C22A4200002F641A1B13111435351919323200
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010 (VW37)
ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
VCID: 77A0835ABF46CA33FE5-8022
1 Fault Found:
32951 - Control Module for Electronic Parking Brake
C10E2 54 [136] - Missing Calibration / Basic Setting
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 37798 km
Date: 2022.08.26
Time: 14:59:38
Sen detta Efter att jag kört test efter att problemet kom tillbaka.
Wednesday,31,August,2022,18:15:24:47336
www.Ross-Tech.com
Address 10: Park/Steer Assist Labels: 5Q0-919-298.clb
Control Module Part Number: 3Q0 919 298 B HW: 3Q0 919 298
Component and/or Version: PLA 3.0 12K H09 0029
Software Coding: 0231563A51
ASAM Dataset: EV_EPHBO2CVW3260000 010016 (VW37)
ROD: EV_EPHBO2CVW3260000.rod
VCID: 3C2A5C76C6E0296BD37-8068
1 Fault Found:
13637120 - Databus
U1123 00 [008] - Received Error Message
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 32
Mileage: 37798 km
Date: 2022.08.26
Time: 14:47:36
och denna
Wednesday,31,August,2022,18:17:30:47336
www.Ross-Tech.com
VIN: WVGZZZ5NZJW326615 License Plate: YPW686 NEW
Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.clb
2 Faults Found:
32800 - Supply Voltage for Left Parking Brake Motor
C100D F0 [137] - Short Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 37798 km
Date: 2022.08.29
Time: 18:15:39
32801 - Supply Voltage for Right Parking Brake Motor
C100E F0 [137] - Short Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 37798 km
Date: 2022.08.29
Time: 18:15:39
2022-08-31, 20:28 #2
- Claes
- 5513
- Mark
- 17
Å då körde jag en full kontroll
kolla txt fil
2022-08-31, 23:31 #3
- 1 684
Har du provat att radera felkoden? Och de andra felkoderna?
2022-09-01, 00:09 #4
Din bil är en MQB bil. Jag har bytt bakre pads på Golf och Seat bilar 2014 respektive 2018 som bägge är MQB bilar. Har använt VCDS på Golfen och OBDeleven PRO next gen på Seaten. Bägge bilarna har genererat felkod i modul 03 i samband bytet. Jag följt proceduren man som man ska (Start lining change mode/End lining change mode). Jag raderade felkoden ifråga som inte kom tillbaka. Allt ok efter det. Kan inte säga var det var för felkod tyvärr.
Du har ju flera andra felkoder enligt bifogad fil som inte har med denna reparation att göra, dem går jag inte in på.Golf 7 Alltrack DSG -18/ Seat Leon Cupra -:R -18/ Skoda Fabia -18
2022-09-01, 07:51 #5
- Claes
- 5513
- Mark
- 17
AndySwede
Jag har raderat felkoden för bromsen. Även kört funktions testen för broms mekanismen i vcds.
Den säger att allt är ok ,sen funkar det några gånger med i & ur av e-bromsen.
Peter-C
Jag vill inte *tömma* koderna innan jag kollat upp alla.
1 ev 2 fel hör ju till E-broms felet (typ auto hold).
Problemet är ju att den säger att den inte är kalibrerad H-bak först,**32951 - Control Module for Electronic Parking Brake
C10E2 54 [136] - Missing Calibration / Basic Setting***
Sen körde jag testet & allt var ok.
Allt funkar & låter som det ska ett par gånger , tills det att e-bromsen blinkar och säger typ *broms servo fel* i instrumenteringen.
Nu funkar inte bromsen att lägga i igen utan blinkar bara...
Då kör jag testet igen & får
felmeddelandet 2 kortslutning på bägge bak??? Fortfarande hör jag dom snurrar i oken.****32800 - Supply Voltage for Left Parking Brake Motor
C100D F0 [137] - Short Circuit + 32801 - Supply Voltage for Right Parking Brake Motor
C100E F0 [137] - Short Circuit***
Har testat att radera detta också men då kommer vi först tillbaka till kalibrering igen .
Så det är som en ond cirkel...
2022-09-01, 13:22 #6
Okay. Hö/vä sida "kortslutning" säger den. Har du kommit åt någon kabel till handbromsen? Annars vet jag tyvärr inte vad man ska gå vidare med, har ju ej haft detta problem.
2022-09-01, 18:42 #7
- Claes
- 5513
- Mark
- 17
Problemet är att allt låter som om det funkar , E-Bromsen tar också.
Så ja tror inte på kortis, eftersom den kan göra testet.
2022-09-01, 20:27 #8
Bara för att vara extra tydlig. Denna procedur har jag praktiserat genom åren. 6 år gammal tråd.....
https://www.gtiklubben.nu/forum/show...l=1#post229502
Vi får väl se om någon annan har lite med input för att skapa klarhet i ärendet.
Byte av skivor samt belägg bak (skoda roomster 2010)
Av Erik133 i forum Skoda-forumSvar: 0Senaste inlägg: 2022-03-12, 21:53 -
Byta skivor och belägg Golf GTI 7
Av RNEH i forum VW-forumSvar: 3Senaste inlägg: 2018-04-10, 12:11 -
passat 2012 byte av skivor belägg bsk
Av wrom i forum VW-forumSvar: 3Senaste inlägg: 2014-07-24, 09:40 -
Skivor/belägg till IV r32
Av Exelon i forum VW-forumSvar: 5Senaste inlägg: 2010-07-10, 00:15 -
Dax för byte av skivor och belägg GTI-88
Av Fenix i forum VW-forumSvar: 6Senaste inlägg: 2007-11-27, 18:57
