Resultat 1 till 14 av 14
2021-06-10, 18:46 #1
Golf 7 ABS uppgradering med problem
Har bytt ABS till 3Q0 idag, men med diverse återstående problem.
Bytte ABS pga BSD/RTA monteringen, som fortfarande inte fungerar
Så om någon är motiverad till att hitta något fel i min ABS kodning, så vore det toppen..
Får inte skriva mer än 10000 tecken... Så det här blev kvar..
Thursday,10,June,2021,16:08:32:21522
VCDS Version: 21.3.0.0 (x64) HEX-NET: 0.4543.4
Data version: 20210226 DS325.0
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010[/FONT][/COLOR]
44-Steering Assist -- Status: OK 0000[COLOR=#141414][FONT=Verdana]
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CPTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 AD HW: 04E 907 309 G
Component: R4 1.4l TFS H02 9225
Revision: WKH02---
Coding: 0125003A247405083000
Shop #: WSC 61962 003 1048576
ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
ROD: EV_ECM14TFS01104E906016AD.rod
VCID: E4840921EF0F2DABC7-80B0
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61136000001318
Coding: 01FA6AA12421116D0779060141C52980562488E0608294F318 22F06210A2
Shop #: WSC 12345 666 45678
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: FAB857597D8BCB5B0D-80AE
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial number: 61131322600084
Coding: 0031061151
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: BD329C452C253C6368-80E8
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0141
Serial number: 12071376510039
Coding: 001C1D00FE033B
ASAM Dataset: EV_ACCMRRBoschVW372 001013
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: B52284651415E423A0-80E0
1 Fault Found:
1043 - Automatic Distance Control
B10E7 F0 [008] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 100220 km
Date: 2021.06.10
Time: 15:57:41
Control Module temperature: 53 °C
Voltage terminal 15: 12.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G0 920 871 HW: 5G0 920 871
Component: KOMBI 353 2210
Coding: 03A519186F9C00081D887E0B440000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: E79E1E2D1E3946B3E2-80B2
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000846596
Coding: 030100342B086400EF00065E1C0F0001000100000000000000 0000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: BB36925D3231325356-80EE
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
H14 0035
Serial number: 02130001613530033155
Coding: 2D0000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3637991103
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0402084260
Coding: 02032103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: BC349141373F356B5F-80E8
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0388577079
Coding: 020321
1 Fault Found:
338048 - Databus
U1123 00 [009] - Received Error Message
[Parkhilfe_01::PH_Tongeber_H_verfuegbar]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 100220 km
Date: 2021.06.10
Time: 15:58:23
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Coding: 1301
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
VCID: B326BA7D1A61FA138E-80E6
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 5G0 035 020 H HW: 5G0 035 020
Component: MU-H-ND-EU H40 0192
Serial number: A458H0D7500229
Coding: 027300010000000021111202002800001F0100340100010097
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 9E707BC981E3477B51-80CA
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H42 0020
Serial number: VWZ8Z9N2300V09
Data carrier:
Subsystem 2 - Part No SW: V03 959 806 MR HW: -----------
Component: ECE 2021 --- 0189
Serial number: --------------------
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1008
1 Fault Found:
7175 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 100220 km
Date: 2021.06.10
Time: 15:57:46
Voltage terminal 30: 12.6 V
BAP-BAP_Function_ID: 02
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
Component: MQB_MFK H05 0051
Serial number: 00000107988
Coding: 0101020001020303010301010100000101
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: BA3897593D0B0B5B4D-80EE
2021-06-11, 10:31 #2
- 2 027
Tycker jag har koll på några saker i bilarna i VAG familjen, men här är jag borta. BSD/RTA? Vad har du gjort och varför? Och vad är det som inte funkar förutom det uppenbara i din scan?
2021-06-11, 21:03 #3
Har kommit lite längre nu
Monterade radar bak (side assist), men kunde inte koda ABS..
(Beställde radar-kittet när jag var ute på jobb, så visste inte vilken ABS som satt i bilen..)
Så det monterades ny ABS 3Q0, som inte ville prata med PLA-modulen..
Nu har jag PLA 3.0 5QA modul monterad, men den tycker inte om instrumentet
Så egentligen är det bara handbromsen som måste "lossas för hand".. Men det får vänta tills efter helgen.. Om ingen annan har något tips
ABS har numera denna koden:
01FA6AA12421116D0779060141C52980562488E0608294F338 2250629082
2021-07-11, 09:44 #4
Har bytt instrument, men får Fel: räckvidd..
Detta skall kunna lösas med nyare gateway, uppdatera (har redan senaste) eller ny "dataset RWB"...
Någon som vet hur man lägger in ny RWB (range calculation)?
2021-07-12, 13:17 #5
- 2 027
Nix. Är det nåt som ska kalibreras eller fil som ska skjutas in?
2021-07-12, 14:39 #6
Ja, men har inte hittat något i ODIS än.. Funderar på att programmera AJ uppdateringen med vcp.. Men är den inte kompatibel kan jag inte använda bilen utan att byta till en annan Gateway.. Hittar inte M, som den redan har..
2021-07-13, 08:16 #7
Ska se om jag får tid att testa filen idag.. Tvivlar lite på positivt resultat..
2021-07-13, 17:20 #8
- 2 027
Så spännande
2021-07-16, 10:02 #9
Odis klarar såklart inte parametrarna för något annat än ursprung-modulen..
Beställde en VCP, den ska "fixa biffen"..
Felet med "Fel: räckvidd" är iallafall borta..
Men med R-instrumentet visar den service och inspection (om 30000km 720dgr) varje gång man slår på tändningen.. Är det verkligen rätt?
2021-07-16, 12:44 #10
- 2 027
Det verkar inte rätt. Testa att göra en SRI. Återstående dagar och km kan du ju lägga in manuellt.
2021-07-16, 13:00 #11
Provat SRI med vcds, ODIS online och Maxisys..
Ska ta en titt när UPS kommer med VCP-kabeln, börjar bli lite trött på Golfen, det tar ju aldrig slut
2021-07-24, 19:06 #12
Då vart Gateway uppdaterad till AJ och parameterdata skrivet med VCP.
Nu fungerar allt, tills nästa eftermontering
2021-07-27, 18:45 #13
- 2 027
Ok! Vad valde du för fil till GW? En med annat versionsnummer eller bokstav eller annan bilmodell?
2021-07-28, 19:39 #14
5Q0907530AJ filen fungerade fin fint..
Samma som jag hade flashat Gatewayen till..
Golf 7 (2016) uppgradering av standardstereo
Av Salve i forum VW-forumSvar: 6Senaste inlägg: 2016-10-27, 23:40 -
Golf v gti uppgradering till ko4
Av udo i forum VW-forumSvar: 5Senaste inlägg: 2014-09-24, 00:05 -
Uppgradering av elektroniska spridare Golf mk2 med Digifant
Av Janne.M i forum VW-forumSvar: 5Senaste inlägg: 2010-08-18, 00:45 -
Ang. toppfart/uppgradering Golf V GTI
Av Ilskog i forum VW-forumSvar: 86Senaste inlägg: 2009-04-08, 19:18 -
Golf GTI mk4 - frågor uppgradering/trimmning av motor
Av mtm i forum VW-forumSvar: 18Senaste inlägg: 2008-07-25, 19:59
