Ämne: Felkoder VW Passat B7
2019-09-07, 15:24 #1
- Marcus johansson
- kristinehamn
- 162
Har dessa intressanta koder. vad kan man dra för slutsatser? Kan inte lägga upp hela listan då den blev för lång.
Saturday,07,September,2019,13:37:31:61016
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ3CZDE078404 License Plate: PAPPA
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 4F 52 53 55
56 61 62 69 6C 72 77
VIN: WVWZZZ3CZDE078404 Mileage: 93710km-58228miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J291245
Coding: 0030007
Shop #: WSC 05311 000 00000
VCID: 6889B8050E7D3EC7629-803C
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 195
Mileage: 83802 km
Time Indication: 0
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0005914876
Coding: 0200B6
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 3635267D18C99837205-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0503
Serial number: 00000003172501
Coding: 010090
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 92093 km
Date: 2019.08.13
Time: 19:28:14
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__107 VW10 HI 2118
Revision: 24017000 Serial number: 003L7PME5VHG
Coding: 0012343
VCID: 7CA1F4556AE58267961-8028
Subsystem 1 - Serial number: 6332MTS670162642
Subsystem 2 - Serial number: 6342MTS606152632
Subsystem 3 - Serial number: 6351HTS6HJ24GBKJ
Subsystem 4 - Serial number: 6361HTS6J6VJHBKR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 91666 km
Time Indication: 0
Date: 2013.12.25
Time: 12:39:60
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004803
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 75B7E171454FD32FE9F-8020
3 Faults Found:
9474161 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Mileage: 93056 km
Date: 2019.08.25
Time: 10:40:17
9474417 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 182
Mileage: 92527 km
Date: 2019.08.20
Time: 12:18:57
9484401 - Motor for Indirect Ventilation Flap
B10B8 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 192
Mileage: 92527 km
Date: 2019.08.20
Time: 12:18:57
2019-09-07, 22:20 #2
- 2 473
Felkoden i 6D har du kört med i 1000mil. Innan du oroar dig har du väl provat att radera samtliga felkoder?
Senast redigerad av vfr den 2019-09-08 klockan 09:42. Anledning: Borttagning av stor onödig citering
2019-09-08, 16:50 #3
- Marcus johansson
- kristinehamn
- 162
#Airbag felkoden är jag till 99% säker på att jag måste byta nyckelavstängningen i handskfacket snart.
#Backkameran vet jag inte vad det är för fel. Går inte att radera den alls och märker inget på funktionen.
#Auto HVAC kan vara motorn som styr ACC? Får ingen kyla i bilen tycker jag. Den felkoden gick också att radera.
#Door & center electric felkoder gick också att ta bort.
Så det är egentligen bara Auto HVAC och backkameran som jag undrar över just nu.
2019-09-09, 11:46 #4
- 2 473
Felkoden på backkameran har jag sett många gånger utan att det varit något fel på funktionen.
För HVAC kan du testa att göra en grundinställning för klimatanläggningen. Öppnar inte spjällen får du inte ut luften, varken varm eller kall.
2019-09-16, 09:39 #5
- Marcus johansson
- kristinehamn
- 162
Om grundinställningen som du menar betyder hålla inne de 2 knapparna så har jag gjort det. Ingen kyla kommer ändå, kan man kolla med VCDS om det finns kylmedel i systemet?
2019-09-16, 12:05 #6
- 2 473
I #8 HVAC finns en funktion att adaptera/grundinställa klimatanläggningens motorstyrda spjäll. Det är den enklaste och billigaste felsökningen i detta läge. Gör den och kvittera felkoder igen.
2019-09-16, 18:58 #7
- Mex
- 1 424
6C är väl den vanliga språk-krocken mellan radio och instrument, bara byta till samma språk..
2019-09-16, 22:33 #8
- Marcus johansson
- kristinehamn
- 162
Vibrationer Passat B7
Av floydian1 i forum VW-forumSvar: 8Senaste inlägg: 2019-06-13, 22:25 -
Vänster hel/halvljus lagt av VW Passat 2014 B7
Av Gavelin i forum VW-forumSvar: 0Senaste inlägg: 2018-08-21, 19:54 -
Låsproblem passat b7
Av Elias i forum VW-forumSvar: 10Senaste inlägg: 2018-01-24, 12:53 -
VW Passat B7 2012 170 TDI DSG Sliter insida däck bak
Av Maxizor i forum VW-forumSvar: 4Senaste inlägg: 2017-04-12, 10:21 -
VW Passat -05 felkoder
Av KoolaVippen i forum VW-forumSvar: 2Senaste inlägg: 2010-08-06, 01:31
