    Marcus johansson
    kristinehamn
    Felkoder VW Passat B7
    Har dessa intressanta koder. vad kan man dra för slutsatser? Kan inte lägga upp hela listan då den blev för lång.
    Saturday,07,September,2019,13:37:31:61016
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20190529 DS308.0
    www.Ross-Tech.com
    VIN: WVWZZZ3CZDE078404 License Plate: PAPPA
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 4F 52 53 55
    56 61 62 69 6C 72 77
    VIN: WVWZZZ3CZDE078404 Mileage: 93710km-58228miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
    Part No SW: 3C9 907 441 HW: 3C9 907 441
    Component: J772__Rearview 0020
    Revision: 00H11000 Serial number: 525PA8-J291245
    Coding: 0030007
    Shop #: WSC 05311 000 00000
    VCID: 6889B8050E7D3EC7629-803C
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 195
    Mileage: 83802 km
    Time Indication: 0
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
    Component: TUER-SG BT 002 0533
    Revision: 14110009 Serial number: 0005914876
    Coding: 0200B6
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
    VCID: 3635267D18C99837205-8062
    Slave Passenger:
    Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 004 0503
    Serial number: 00000003172501
    Coding: 010090
    1 Fault Found:
    67589 - Turn Signal in Exterior Mirror
    B11FD 01 [008] - Electrical Failure
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 176
    Mileage: 92093 km
    Date: 2019.08.13
    Time: 19:28:14
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
    Component: J234__107 VW10 HI 2118
    Revision: 24017000 Serial number: 003L7PME5VHG
    Coding: 0012343
    VCID: 7CA1F4556AE58267961-8028
    Subsystem 1 - Serial number: 6332MTS670162642
    Subsystem 2 - Serial number: 6342MTS606152632
    Subsystem 3 - Serial number: 6351HTS6HJ24GBKJ
    Subsystem 4 - Serial number: 6361HTS6J6VJHBKR
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    1 Fault Found:
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    008 - Implausible Signal - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 91666 km
    Time Indication: 0
    Date: 2013.12.25
    Time: 12:39:60
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
    Component: Climatronic H03 0303
    Revision: 00001K02
    Coding: 0014004803
    Shop #: WSC 00015 115 00000
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW46.rod
    VCID: 75B7E171454FD32FE9F-8020
    3 Faults Found:
    9474161 - Motor for Defroster Flap
    B1090 71 [008] - Actuator stuck
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 210
    Mileage: 93056 km
    Date: 2019.08.25
    Time: 10:40:17
    9474417 - Motor for Front Air Distribution Flap
    B1091 71 [008] - Actuator stuck
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 92527 km
    Date: 2019.08.20
    Time: 12:18:57
    9484401 - Motor for Indirect Ventilation Flap
    B10B8 71 [008] - Actuator stuck
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 192
    Mileage: 92527 km
    Date: 2019.08.20
    Time: 12:18:57
    Andreas VCDS
    Felkoden i 6D har du kört med i 1000mil. Innan du oroar dig har du väl provat att radera samtliga felkoder?
    Senast redigerad av vfr den 2019-09-08 klockan 08:42. Anledning: Borttagning av stor onödig citering
    Marcus johansson
    kristinehamn
    #Airbag felkoden är jag till 99% säker på att jag måste byta nyckelavstängningen i handskfacket snart.
    #Backkameran vet jag inte vad det är för fel. Går inte att radera den alls och märker inget på funktionen.
    #Auto HVAC kan vara motorn som styr ACC? Får ingen kyla i bilen tycker jag. Den felkoden gick också att radera.
    #Door & center electric felkoder gick också att ta bort.
    Så det är egentligen bara Auto HVAC och backkameran som jag undrar över just nu.
    Andreas VCDS
    Felkoden på backkameran har jag sett många gånger utan att det varit något fel på funktionen.
    För HVAC kan du testa att göra en grundinställning för klimatanläggningen. Öppnar inte spjällen får du inte ut luften, varken varm eller kall.
    Marcus johansson
    kristinehamn
    Om grundinställningen som du menar betyder hålla inne de 2 knapparna så har jag gjort det. Ingen kyla kommer ändå, kan man kolla med VCDS om det finns kylmedel i systemet?
    Andreas VCDS
    I #8 HVAC finns en funktion att adaptera/grundinställa klimatanläggningens motorstyrda spjäll. Det är den enklaste och billigaste felsökningen i detta läge. Gör den och kvittera felkoder igen.
    Rikard Sers
    6C är väl den vanliga språk-krocken mellan radio och instrument, bara byta till samma språk..
    Marcus johansson
    kristinehamn
    Kan du beskriva mer ��
  1. Vibrationer Passat B7
    Av floydian1 i forum VW-Forum
    Senaste inlägg: 2019-06-13, 21:25
  2. Svar: 0
    Senaste inlägg: 2018-08-21, 18:54
  3. Låsproblem passat b7
    Av Elias i forum VW-Forum
    Senaste inlägg: 2018-01-24, 11:53
  4. Svar: 4
    Senaste inlägg: 2017-04-12, 09:21
  5. VW Passat -05 felkoder
    Av KoolaVippen i forum VW-Forum
    Senaste inlägg: 2010-08-06, 00:31
