    sep 2010
    Lars Ödlund
    Visby
    Startproblem, någon idé?
    Var iväg och felsökte en bekants bil i morse, den har tydligen slutat att starta redan i fjol..
    Startmotorn snurrar normalt men VCDS gav spännande resultat. (Ja jag kör med 18.9 som jag förklarat förut eftersom något i de nyare inte är kompatibla med något i laptopen jag använder)
    Friday,09,July,2021,15:06:06:59248
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.1.0
    Data version: 20190114 DS296.0
    www.Ross-Tech.com
    VIN: TMBJX11U842904115 License Plate:
    Chassis Type: 1U (1U - Skoda Octavia (1997 > 2011))
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
    VIN: TMBJX11U842904115 Mileage: 206610km-128381miles
    Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
    Part No: 1C0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0001025
    Shop #: WSC 31480 000 00000
    VCID: 3365C08851D218D210-5106
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 601
    Component: 2T AIRBAG VW51 0008
    Coding: 12884
    Shop #: WSC 31480
    VCID: 5DB14630D7D6FEA296-50E8
    No fault code found.
    Address 17: Instruments Labels: 1U0-920-xxx-17.lbl
    Part No: 1U0 920 811 B
    Component: KOMBI+WEGFAHRSP VDO V11
    Coding: 21113
    Shop #: WSC 31480
    VCID: 2D51D6F0E7F64E2246-50E8
    TMBJX11U842904115 SKZ7Z0D2384469
    6 Faults Found:
    00771 - Fuel Level Sensor (G)
    30-10 - Open or Short to Plus - Intermittent
    00562 - Sensor for Oil Level/Temperature (G266)
    30-00 - Open or Short to Plus
    01177 - Engine Control Unit
    64-10 - Not Currently Testable - Intermittent
    49-00 - No Communications
    01336 - Company Data Bus for Comfort System
    49-10 - No Communications - Intermittent
    80-10 - Single-Wire Operation - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 31480
    VCID: 70EF0F84304463CA2D-50E8
    4 Faults Found:
    01332 - Door Control Module; Passenger Side (J387)
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 A
    Component: 4Z Komfortgerát HLO 0003
    Coding: 00067
    Shop #: WSC 31480
    VCID: 3561FE900FA606E23E-4AE8
    Subsystem 1 - Part No: 1U4959801D
    Component: 4Z Tõrsteuer.FS KLO 0202
    Subsystem 2 - Part No: 1U4959802D
    Component: 4Z Tõrsteuer.BF KLO 0202
    23 Faults Found:
    01362 - Close Switch for Tailgate/Trunk (F124)
    29-10 - Short to Ground - Intermittent
    01330 - Central Control Module for Central Convenience (J393)
    53-10 - Supply Voltage Too Low - Intermittent
    37-10 - Faulty - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    01299 - Diagnostic Interface for Data Bus (J533)
    01134 - Alarm Horn (H12)
    01135 - Interior Monitoring Sensors
    36-10 - Open Circuit - Intermittent
    01044 - Control Module Incorrectly Coded
    35-00 - -
    00912 - Window Regulator Switch; Front Left (E40)
    27-10 - Implausible Signal - Intermittent
    00913 - Window Regulator Switch; Front Right Driver (E81)
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
    00915 - Window Regulator Switch; Rear Right; Driver (E55)
    01034 - Electric Window Thermal Protection Active; Driver
    35-10 - - - Intermittent
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    27-00 - Implausible Signal
    01359 - Internal Central Locking Switch; Passenger Side (E198)
    End-------------------------(Elapsed Time: 04:09)--------------------------
    Övriga styrenheter får den ingen kontakt med.
    Helt nytt fulladdat batteri, ovan är felkoderna efter att de ursprungliga raderats, de som ligger kvar alltså.
    Rikard
    Skoda? Har du mer info?
    Kolla säkringarna!
    sep 2010
    Lars Ödlund
    Visby
    Kolla säkringarna!
    Ja den hamnade i fel forumdel :-( En Octavia runt 2001-2002.
    Köptes i fjol sommar, slutade att starta efter av man städat bilen invändigt.
    Säkringar kollade och spänningsmätta.
    Anslutning till motorstyrdon kollad.
    Någon vajsing med CAN-bussen, ta ett titt i ett kopplingsschema och följ canbusshärvorna för att leta fel
    Henrik Carlqvist
    Linköping
    Nu vet jag inte hur det är med just den bilmodellen, men många bilar har elektroniklådor på golvet under något framsäte. Dessa sitter ofta utsatt till om man av en eller annan anledning skulle få in vatten i kupen. Kolla om ni har någon sådan låda och om den verkar frisk. Om du har tur kanske de bara råkat rycka ur någon kontakt till lådan med dammsugaren.
    Jag hoppas att de inte gjorde såhär när de städade bilen invändigt:
    https://www.youtube.com/watch?v=J_FtEmkPIMk
    Lossa härvan på en box/dörr i taget och provstarta
    sep 2010
    Lars Ödlund
    Visby
    Detta är kollat och tydligen var den boxen urdragen vid testtillfället :-( Hjälper dock inte med primärfelet.
    sep 2010
    Lars Ödlund
    Visby
    Relät (458) i elboxen i motorrummet, vad styr det? + matning till styrboxen?
    Tänkte bygla sockeln för att se om felet möjligen kan vara där, verkar kunna ge liknande resultat enligt vad sökningar med Google visat.
  1. Startproblem GTi mk6
    Av BigGreek i forum VW-forum
    Senaste inlägg: 2017-12-28, 17:07
  2. Svar: 4
    Senaste inlägg: 2015-04-29, 21:05
  3. Svar: 1
    Senaste inlägg: 2014-08-22, 22:28
  4. startproblem gti 16 v -87
    Av bumpen73 i forum VW-forum
    Svar: 13
    Senaste inlägg: 2008-08-16, 06:44
  5. Startproblem
    Av Skooghe i forum VW-forum
    Svar: 20
    Senaste inlägg: 2007-10-23, 19:17
