Resultat 1 till 14 av 14
    Rikard
    Golf 7 ABS uppgradering med problem
    Har bytt ABS till 3Q0 idag, men med diverse återstående problem.
    Bytte ABS pga BSD/RTA monteringen, som fortfarande inte fungerar
    Så om någon är motiverad till att hitta något fel i min ABS kodning, så vore det toppen..
    Får inte skriva mer än 10000 tecken... Så det här blev kvar..
    Thursday,10,June,2021,16:08:32:21522
    VCDS Version: 21.3.0.0 (x64) HEX-NET: 0.4543.4
    Data version: 20210226 DS325.0
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    3C-Lane Change -- Status: Malfunction 0010[/FONT][/COLOR]
    44-Steering Assist -- Status: OK 0000
    [COLOR=#141414][FONT=Verdana]
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    A5-Frt Sens. Drv. Assist -- Status: OK 0000
    Address 01: Engine (J623-CPTA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04E 906 016 AD HW: 04E 907 309 G
    Component: R4 1.4l TFS H02 9225
    Revision: WKH02---
    Coding: 0125003A247405083000
    Shop #: WSC 61962 003 1048576
    ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
    ROD: EV_ECM14TFS01104E906016AD.rod
    VCID: E4840921EF0F2DABC7-80B0
    No fault code found.
    Readiness: 0110 0001
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
    Component: ESC H42 0723
    Revision: 00000000 Serial number: 61136000001318
    Coding: 01FA6AA12421116D0779060141C52980562488E0608294F318 22F06210A2
    Shop #: WSC 12345 666 45678
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
    ROD: EV_Brake1UDSContiMK100IPB_034.rod
    VCID: FAB857597D8BCB5B0D-80AE
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
    Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
    Component: PARKHILFE PLA 011 0029
    Revision: -------- Serial number: 61131322600084
    Coding: 0031061151
    ASAM Dataset: EV_EPHVA2CAU3700000 003014
    ROD: EV_EPHVA2CAU3700000_003.rod
    VCID: BD329C452C253C6368-80E8
    Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
    Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
    Component: ACC Bosch MQB H03 0141
    Serial number: 12071376510039
    Coding: 001C1D00FE033B
    ASAM Dataset: EV_ACCMRRBoschVW372 001013
    ROD: EV_ACCMRRBoschVW372_VW26.rod
    VCID: B52284651415E423A0-80E0
    1 Fault Found:
    1043 - Automatic Distance Control
    B10E7 F0 [008] - Disconnected
    [FAULT_CIS_TSK_IRREV_FAIL]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 100220 km
    Date: 2021.06.10
    Time: 15:57:41
    Control Module temperature: 53 °C
    Voltage terminal 15: 12.3 V
    Vehicle speed: 0.00 m/s
    Acceleration: 0.00 m/s²
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 5G0 920 871 HW: 5G0 920 871
    Component: KOMBI 353 2210
    Coding: 03A519186F9C00081D887E0B440000
    ASAM Dataset: EV_DashBoardVDDMQBAB 008031
    ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
    VCID: E79E1E2D1E3946B3E2-80B2
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
    Component: GW MQB High 125 1144
    Revision: -------- Serial number: 0000846596
    Coding: 030100342B086400EF00065E1C0F0001000100000000000000 0000000000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_GatewLear 009013
    ROD: EV_GatewLear_009.rod
    VCID: BB36925D3231325356-80EE
    Generator:
    Multifunction steering wheel control module:
    Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
    H14 0035
    Serial number: 02130001613530033155
    Coding: 2D0000
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
    Component: J367-BDMHella H03 8042
    Serial number: 3637991103
    Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
    Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
    Component: HRE_Master H12 0071
    Serial number: 0402084260
    Coding: 02032103
    ASAM Dataset: EV_HREntryHella 001028
    ROD: EV_HREntryHella_VW37.rod
    VCID: BC349141373F356B5F-80E8
    Lane change assistance control module 2:
    Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
    Component: HRE_Slave H11 0071
    Serial number: 0388577079
    Coding: 020321
    1 Fault Found:
    338048 - Databus
    U1123 00 [009] - Received Error Message
    [Parkhilfe_01::PH_Tongeber_H_verfuegbar]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 100220 km
    Date: 2021.06.10
    Time: 15:58:23
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
    Component: EPS_MQB_ZFLS 502 5011
    Coding: 1301
    ASAM Dataset: EV_SteerAssisMQB 009026
    ROD: EV_SteerAssisMQB_009_VW37.rod
    VCID: B326BA7D1A61FA138E-80E6
    Address 5F: Information Electr. (J794) Labels:* None
    Part No SW: 5G0 035 020 H HW: 5G0 035 020
    Component: MU-H-ND-EU H40 0192
    Serial number: A458H0D7500229
    Coding: 027300010000000021111202002800001F0100340100010097
    ASAM Dataset: EV_MUHig4CHBAS 001040
    ROD: EV_MUHig4CHBAS_VW37.rod
    VCID: 9E707BC981E3477B51-80CA
    Display and control head 1 for information electronics:
    Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
    Component: ABT_High H42 0020
    Serial number: VWZ8Z9N2300V09
    Data carrier:
    Subsystem 2 - Part No SW: V03 959 806 MR HW: -----------
    Component: ECE 2021 --- 0189
    Serial number: --------------------
    Compact disc data bank:
    Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote --- 1008
    1 Fault Found:
    7175 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 100220 km
    Date: 2021.06.10
    Time: 15:57:46
    Voltage terminal 30: 12.6 V
    BAP-BAP_Function_ID: 02
    Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
    Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
    Component: MQB_MFK H05 0051
    Serial number: 00000107988
    Coding: 0101020001020303010301010100000101
    ASAM Dataset: EV_MFKBoschAU370 001001
    ROD: EV_MFKBoschAU370.rod
    VCID: BA3897593D0B0B5B4D-80EE
    Tycker jag har koll på några saker i bilarna i VAG familjen, men här är jag borta. BSD/RTA? Vad har du gjort och varför? Och vad är det som inte funkar förutom det uppenbara i din scan?
    Rikard
    Har kommit lite längre nu
    Monterade radar bak (side assist), men kunde inte koda ABS..
    (Beställde radar-kittet när jag var ute på jobb, så visste inte vilken ABS som satt i bilen..)
    Så det monterades ny ABS 3Q0, som inte ville prata med PLA-modulen..
    Nu har jag PLA 3.0 5QA modul monterad, men den tycker inte om instrumentet
    Så egentligen är det bara handbromsen som måste "lossas för hand".. Men det får vänta tills efter helgen.. Om ingen annan har något tips
    ABS har numera denna koden:
    01FA6AA12421116D0779060141C52980562488E0608294F338 2250629082
    Rikard
    Har bytt instrument, men får Fel: räckvidd..
    Detta skall kunna lösas med nyare gateway, uppdatera (har redan senaste) eller ny "dataset RWB"...
    Någon som vet hur man lägger in ny RWB (range calculation)?
    Nix. Är det nåt som ska kalibreras eller fil som ska skjutas in?
    Rikard
    Ja, men har inte hittat något i ODIS än.. Funderar på att programmera AJ uppdateringen med vcp.. Men är den inte kompatibel kan jag inte använda bilen utan att byta till en annan Gateway.. Hittar inte M, som den redan har..
    Rikard
    Ska se om jag får tid att testa filen idag.. Tvivlar lite på positivt resultat..
    Så spännande
    Rikard
    Odis klarar såklart inte parametrarna för något annat än ursprung-modulen..
    Beställde en VCP, den ska "fixa biffen"..
    Felet med "Fel: räckvidd" är iallafall borta..
    Men med R-instrumentet visar den service och inspection (om 30000km 720dgr) varje gång man slår på tändningen.. Är det verkligen rätt?
    Det verkar inte rätt. Testa att göra en SRI. Återstående dagar och km kan du ju lägga in manuellt.
    Rikard
    Provat SRI med vcds, ODIS online och Maxisys..
    Ska ta en titt när UPS kommer med VCP-kabeln, börjar bli lite trött på Golfen, det tar ju aldrig slut
    Rikard
    Då vart Gateway uppdaterad till AJ och parameterdata skrivet med VCP.
    Nu fungerar allt, tills nästa eftermontering
    Ok! Vad valde du för fil till GW? En med annat versionsnummer eller bokstav eller annan bilmodell?
    Rikard
    5Q0907530AJ filen fungerade fin fint..
    Samma som jag hade flashat Gatewayen till..
  1. Svar: 6
    Senaste inlägg: 2016-10-27, 23:40
  2. Golf v gti uppgradering till ko4
    Av udo i forum VW-forum
    Senaste inlägg: 2014-09-24, 00:05
  3. Svar: 5
    Senaste inlägg: 2010-08-18, 00:45
  4. Ang. toppfart/uppgradering Golf V GTI
    Av Ilskog i forum VW-forum
    Svar: 86
    Senaste inlägg: 2009-04-08, 19:18
  5. Svar: 18
    Senaste inlägg: 2008-07-25, 19:59
