Golf 7 ABS uppgradering med problem
Har bytt ABS till 3Q0 idag, men med diverse återstående problem.
Bytte ABS pga BSD/RTA monteringen, som fortfarande inte fungerar :p
Så om någon är motiverad till att hitta något fel i min ABS kodning, så vore det toppen..
Får inte skriva mer än 10000 tecken... Så det här blev kvar..
Thursday,10,June,2021,16:08:32:21522
VCDS Version: 21.3.0.0 (x64) HEX-NET: 0.4543.4
Data version: 20210226 DS325.0
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010[/FONT][/COLOR]
44-Steering Assist -- Status: OK 0000[COLOR=#141414][FONT=Verdana]
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CPTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 AD HW: 04E 907 309 G
Component: R4 1.4l TFS H02 9225
Revision: WKH02---
Coding: 0125003A247405083000
Shop #: WSC 61962 003 1048576
ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
ROD: EV_ECM14TFS01104E906016AD.rod
VCID: E4840921EF0F2DABC7-80B0
No fault code found.
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61136000001318
Coding: 01FA6AA12421116D0779060141C52980562488E0608294F318 22F06210A2
Shop #: WSC 12345 666 45678
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: FAB857597D8BCB5B0D-80AE
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: -------- Serial number: 61131322600084
Coding: 0031061151
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: BD329C452C253C6368-80E8
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0141
Serial number: 12071376510039
Coding: 001C1D00FE033B
ASAM Dataset: EV_ACCMRRBoschVW372 001013
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: B52284651415E423A0-80E0
1 Fault Found:
1043 - Automatic Distance Control
B10E7 F0 [008] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 100220 km
Date: 2021.06.10
Time: 15:57:41
Control Module temperature: 53 °C
Voltage terminal 15: 12.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G0 920 871 HW: 5G0 920 871
Component: KOMBI 353 2210
Coding: 03A519186F9C00081D887E0B440000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: E79E1E2D1E3946B3E2-80B2
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000846596
Coding: 030100342B086400EF00065E1C0F0001000100000000000000 0000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: BB36925D3231325356-80EE
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
H14 0035
Serial number: 02130001613530033155
Coding: 2D0000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3637991103
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0402084260
Coding: 02032103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: BC349141373F356B5F-80E8
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0388577079
Coding: 020321
1 Fault Found:
338048 - Databus
U1123 00 [009] - Received Error Message
[Parkhilfe_01::PH_Tongeber_H_verfuegbar]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 100220 km
Date: 2021.06.10
Time: 15:58:23
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Coding: 1301
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
VCID: B326BA7D1A61FA138E-80E6
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 5G0 035 020 H HW: 5G0 035 020
Component: MU-H-ND-EU H40 0192
Serial number: A458H0D7500229
Coding: 027300010000000021111202002800001F0100340100010097
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 9E707BC981E3477B51-80CA
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H42 0020
Serial number: VWZ8Z9N2300V09
Data carrier:
Subsystem 2 - Part No SW: V03 959 806 MR HW: -----------
Component: ECE 2021 --- 0189
Serial number: --------------------
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1008
1 Fault Found:
7175 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 140
Mileage: 100220 km
Date: 2021.06.10
Time: 15:57:46
Voltage terminal 30: 12.6 V
BAP-BAP_Function_ID: 02
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
Component: MQB_MFK H05 0051
Serial number: 00000107988
Coding: 0101020001020303010301010100000101
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: BA3897593D0B0B5B4D-80EE
