Nej precis det har den inte!, S3 känns som en snik R! ;). Den har inte de nya grymma bromsarna som R har mm :)
Tror Audi spar alla gobitar till RS3an som kommer snart ;)
Bromsarna. Som du skriver, S3:an har samma ok som Golf 7 GTIPP/R och S3 8v (föregångaren). Det är enkolvsok, (som funkar kanonbra :)).
Bromsok Golf R mk7:
Bifogad fil 12246
Bromsok S3 8Y (nya S3), identiskt med bilden ovan:
Bifogad fil 12247
R mk8 bromsar, helt annat ok:
http://www.gtiklubben.nu/forum/showt...l=1#post257491
Det hade jag missat, tog för givet att det var samma som nya R.
Jo funkar förvåndasvärd bra!, men jag kör lite bana!. Så dessa nya Bromsar större och tjockare skivor, och som sagt större ok är ju en Galet bra uppdatering!
Nackdelen är att jag inte kan köra med mina snabba 17" r- däck ;). Måste minst ha 18" med dessa bromsar :)
Första provkörningen av Ren..... F***n verkar galet trevlig ;).
https://www.autocar.co.uk/car-review...-r-2021-review
Bifogad fil 12254
Should I buy one?
On first impressions, the new R not only lives up to lofty expectations, but exceeds them.
Yes, it’s quick; perhaps not at the level of the Mercedes-AMG A45, but it certainly has the measure of its key rivals, the Audi S3, BMW M135i and Mercedes-AMG A35 4Matic.
However, it is also a terrifically well balanced car whose traction and exploitability is every bit as impressive as the tractability and superb manners of its reworked engine. For sheer performance and all-season appeal it rises above the new Golf GTI, and comfortably so.
Admittedly, to properly gauge its handling in the dry, we’ll need more favourable weather conditions – and perhaps we’ll get them when we test this car in the UK.
For now, what we can say is that the Golf R’s clever chassis technology brings a broader range of characteristics to the table than before. There’s greater compliance and overall comfort at the more relaxed end of the scale, but added response and even more impressive body control in the more sporting settings than its highly admired predecessor.
Lovorden haglar över R:en i Autocars utvärdering :D!
Dock anmärkning på långsam respons från infotainmentsystemet, ej R relaterat. Uppgradering SW i närtid?
Jag menar att den fortfarande ser ut om en Golf som kostar från 250tkr eller vad det nu kan vara. Golfen är ju på riktigt en Folkvagn för kategorin du räknar upp så ur det perspektivet är 687.200kr befängt - för en folkvagn.
Finns det nu någonstans att lägga laddkablarna?
Nja, kan det vara så illa som medvetet :(... Känns som VW har lite mjukvaru problem just nu. Bara se ID3 som varit galet dålig...men där ska det visst vara mkt bättre nu...
Får ju hoppas man inte köper en Golf för 500 000 + och info systemet laggar som en gammal android platta från 2010 hemma ;)
Håller med rätt galet att man närmar sig 700k för en Golf, vi snackar ju Porsche instegs priser nu ;). Kan säga efter klämt på en 918 så är det en hel annan liga i kvalité mm... :)
Jo man kan bråtta ner den där skitiga och otympliga kabel under golvet lite halvsmidigt ;)...
Är ju inget unikt för VW Golf, enklaste Volvo V60 ser också ut som toppmodellen, för gemene man, trots rejäl prisskillnad. Samma sak med Mercedes A-klass. Teknikinnehållet är däremot radikalt annorlunda.
Laddkablar: jag rekommenderar att använda laddbox med fast kabel.
Det finns offentliga laddstolpar (långsamladdare) med och/eller utan fast laddkabel. Utan fast kabel är det absolut vanligaste. När fast laddkabel saknas använder man sin egen typ 2 kabel som ansluts mellan laddstolpens uttag och bil. Laddhybrid (PHEV) laddar man inte i snabbladdare (som alltid har fast laddkabel), som man kan göra med elbil (BEV). Men jag vill nog påstå att laddmöjlighet hemma eller minst på exempelvis arbetsplats parkering (plats där man uppehåller sig en större del av dygnet) är en förutsättning för att det ska vara meningsfullt med laddhybrid. Hemma ska man naturligtvis välja en laddbox med fast kabel.
"Första" med provkörningen med Clubpsporten!.
De tycker den är rätt ok, fast den kostar så lika Ren i England!. Vi har bra mkt bättre pris på denna i Sverige med samma utrustning!
Där det skiljer typ 80 000 i Sverige mot bara 22 000 i England...Mellan R och Clubsport :)
Läckra Bromsar! :)
https://www.autocar.co.uk/car-review...rt-2020-review
Bifogad fil 12258
Auto Bild körde redan i oktober ;) https://www.autobild.de/artikel/vw-g...-18481547.html
Synd bara att denna lider av samma "fel" som tidigare MQB bilar med tvådelade bromsskivor, nämligen att det sitter en vänsterskiva på båda sidorna av bilen (hålmönstrets riktning avslöjar detta). Hålmönstret i sig spelar ingen roll men som man kan se i bilen ovan är "kylflänsarna" i dessa skivor vinklade och på högersidan av bilen hamnar dessa i fel vinkel.
Undrar om vi nånsin kommer få se en Golf med fabriksmonterade fasta bromsok istället för glidande ok. Det är ju nåt som hittar på konkurrenterna såsom BMW M1xx, Mercedes-AMG A-klass, Honda Civic Type-R, Ford Focus RS (medan den fortfarande fanns), och Renault Mégane R.S. Förekommer även på mindre modeller som Toyota Yaris GR och gamla Yaris GRMN. Även inom VAG koncernen finns ju Seat/Cupra med lång tradition av att erbjuda fasta ok på León, fanns till och med som tillval till Ibiza Cupra en gång i tiden.
Japp, därför man gjorde "" . Men den var jobbigt tysk :), google translate är lite knackigt :)
Ja så sant!, men ett steg fram emot vad man tidigare fått :)
Däremot så skulle man vilja ha dessa, som är ett tillval på Cupra Formenator.. ;)
Bifogad fil 12259
Nya Turbon i Gen 4 888 motorn verkar funka!. Snabbare än en 280hk Fård! :)
Man kanske skulle beställa en vanlig GTI, så man kan få den den där jäkla dragkroken oxå! :)
https://www.youtube.com/watch?v=sOks5XgMlvw
Helvete vilken kärra!!
Bättre än man hoppas!. 4,5sek i blött!!. Sen vilket jäkla ljud ( men bara i Race som låter så, som tur är )?!. Men det BÄSTA!!, den växlar inte upp själv!!!!!!....bara att beställa..
https://www.youtube.com/watch?v=R6td4gyEym4
Härlig bil :) Passa på alla som vill njuta av rolig förbränningsmotorbil. Får EU-politikerna som de vill så klubbas snart Euro 7 med fullständigt orimliga krav på emissionskontroll, vilket kommer att leda till otroliga prisökningar på förbränningsmotorbilar och kanske framför allt att väldigt många modeller och versioner går ur tiden :(
Jo har varit min plan direkt....det här är SISTA roliga förbränningsmotor man kommer kunna köpa..Sen blir ska mm helt knas ;).
Och lastbilarna kan brumma vidare? Det är trots allt de som står för mer utsläpp än personbilarna eftersom transporter med lastbilar fortsätter öka och personbilstrafikens utsläpp minskar.
1300 nya Golf återkallas (i Sverige)
https://www.vibilagare.se/nyheter/vo...a-bromspedalen
I värsta fall kan bromspedalen lossna på omkring 38 000 bilar med automatlåda. Nu måste bilarna tillbaka till verkstaden.
:D
Ja den där Tyska Kvaliten, hoppas den inte blivit sämre. Min 7.5 har varit sjukt bra!, inte ett enda fel på snart 4a år!. :)
Nu kommer man säkert få äta upp detta med en Mk8a sen....där är en anledning att man skulle leasa istället.....men känns ju så tråkigt på en så där typ av bil..:)
Generellt sett ska man väl alltid undvika de första exemplaren. Det är ju först vid produktionens utgång efter typ andra eller tredje generationen som alla barnsjukdomar är avhjälpta, som med din 7,5 ;)
Lite överdrivet. VW har upptäckt något som eventuellt skulle kunna innebära problem, det tyder ju snarare på god kontroll, även på levererade bilar.
Kan ha köpt mig en dyr Julklapp idag :rolleyes:
In och följ och fråga dumma frågor! ;)... Leverans hoppas innan April..
https://www.instagram.com/faceliftgt/
Bifogad fil 12281
Vit R med Performance Pack !;)
Bifogad fil 12282
Jo går att följa detta lilla projekt här om man vill.. :)
Funderar på att köpa Cup2 direkt, eller har ni något bättre val. Man kunde faktiskt lägga till Cup2 från fabrik!. Men det kostade mer än att köpa däcken separat efter...och då även ha kvar de däck följer med ( lite oklart vad det är )
https://youtu.be/q8ETM0_Oyo8
Bifogad fil 12291
Ja visst blir det! :)
De är rätt fullsmetade från fabrik!, men som sagt självklart Performace pack!. Kan tyckas vara lite dyrt för 25k, men det ingår nya hur jäkla snygga som helt 19"arna ( nya versionen av Pretoria typ ), den galna bakspoilern och Drift och ringen läget!. Ringen läget som verkar vara hur brutalt som helst!, kul att det vågat äntligen!. Håller växlarna i varvstoppet och smäller och grejar! haha
Sen slår man på Comfort så kan man glida tyst och mjukt som en gammal Volvo med DCC som jag självklart valde. Är ju 10 lägen nu!, det är både mjukare och hårdare mot Mk7!. Så troligen helt perfekt! :)
Onödigaste Panorama men efter att ha testat 100 olika Gopro kombinationer fäsen, så är det bästa att sätta Gorpon i luckan!. Så blir världens dyraste Gopro fäst!! haha....fast vi andvnder faktiskt luckan bra mkt oxå ;)
Gillar inte förarhjälpmedel, men de fanns en 800:-!!! tilval på det..så det var man ju korkade om man inte valde...;)
Navigator får man som sagt gratis just nu, den fick duga. Finns även en PRO för 7000 till. Då kan man få kartan i displayen framför ratten. Men redan sett att man kan programmera om det själv, gillar ju sånt fix är ju sponsrad av OBD eleven. Så blir ju en bra film på det sen ;)
Sen har jag nya 2021 senaste fälgarna från DOTZ anländer från OCL.. plus lite annat...
Så kan bli ett kul år, ni får hänga med i mina kanaler! :)
Nej för i helvete, helsvart går bara inte i vårat klimat. Jag tänkte på den blåa, med svarta detaljer. Det är också fint.
