Hej.min motorlampa lyser och får fram felkod P0354 trouble cod.
vad kan det vara för fel??
Prova att söka på Google, skriv bara "VW code p0354 då får du fram:
"The Volkswagen trouble code P0354 indicates an "Ignition Coil D Primary/Secondary Circuit Malfunction," meaning there's a fault with the ignition coil for the engine's cylinder 4, the #4 spark plug, or the associated wiring or PCM circuit. Common symptoms include a check engine light, engine misfires, a rough engine idle, and reduced power. Diagnosis typically involves testing the ignition coil, inspecting the wiring and connectors, and checking the spark plug for cylinder 4."
