Har dessa intressanta koder. vad kan man dra för slutsatser? Kan inte lägga upp hela listan då den blev för lång.
Saturday,07,September,2019,13:37:31:61016
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ3CZDE078404 License Plate: PAPPA
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 4F 52 53 55
56 61 62 69 6C 72 77
VIN: WVWZZZ3CZDE078404 Mileage: 93710km-58228miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J291245
Coding: 0030007
Shop #: WSC 05311 000 00000
VCID: 6889B8050E7D3EC7629-803C
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 195
Mileage: 83802 km
Time Indication: 0
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0005914876
Coding: 0200B6
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 3635267D18C99837205-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0503
Serial number: 00000003172501
Coding: 010090
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [008] - Electrical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 92093 km
Date: 2019.08.13
Time: 19:28:14
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__107 VW10 HI 2118
Revision: 24017000 Serial number: 003L7PME5VHG
Coding: 0012343
VCID: 7CA1F4556AE58267961-8028
Subsystem 1 - Serial number: 6332MTS670162642
Subsystem 2 - Serial number: 6342MTS606152632
Subsystem 3 - Serial number: 6351HTS6HJ24GBKJ
Subsystem 4 - Serial number: 6361HTS6J6VJHBKR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 91666 km
Time Indication: 0
Date: 2013.12.25
Time: 12:39:60
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014004803
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 75B7E171454FD32FE9F-8020
3 Faults Found:
9474161 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Mileage: 93056 km
Date: 2019.08.25
Time: 10:40:17
9474417 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 182
Mileage: 92527 km
Date: 2019.08.20
Time: 12:18:57
9484401 - Motor for Indirect Ventilation Flap
B10B8 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 192
Mileage: 92527 km
Date: 2019.08.20
Time: 12:18:57
