5 bifogad(e) fil(er)
Uppgradera min RNS510 osäker om jag väljer rätt Firmware...
Tänkte uppgradera min RNS510 men är osäker om jag väljer rätt Firmware...
Har detta nu...
Bifogad fil 4249
Bifogad fil 4250
Bifogad fil 4251
Bifogad fil 4252
Bifogad fil 4253
Nu till frågan..
På MY-GTI.Com står det följande.
HW Vehicle: 0xC201 – HW Radio: 0004
C6/C7
1T0 035 680 B (1T0035680B)
Firmware version (when hardware last produced): 1300
Firmware version (unmodified releases): 1300
Firmware version (modified releases): 5269
Sedan under länken till Firmware 5269 står följande..
Volkswagen RNS 510 Firmware Upgrade to version 5269
Version 5269 firmware for the Volkswagen RNS 510 and the Skoda Columbus has been released.
Voice Control (requires microphone – see*Volkswagen RNS 510 Microphone Connection for voice control)
NEW DAB+ Support (from 5xxx)
NEW DAB Support (from 4xxx)
NEW Radio Text (from 4xxx)
NEW*Faster navigation and user interface
NEW*Automatic illumination control
NEW*Enhanced destination input
NEW*hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
NEW*Compass
NEW*POI- see*Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
NEW*Languages – Arabic, *Russian, Turkish and Polish
Speed Limit Display
Stability Improvements
Faster Startup (from 2720 onwards)
Display OPS and RVC at the same time
SDHC 32 GB Support (HW04 and above)
Display Off on extras tab
Climatronic control if approriate climatronic fitted
Clock display if RNS 510 swtiched off
Excluded roads (under route options)
GPS coordinates entry
Additional adjustments for video
Larger RVC screen with transparent menus at the side
Units that can be upgraded include (still being compiled may not be 100%)
All D and later versions.
Download Firmware Upgrade
Warning!*There is a remote chance of you ‘bricking’ the unit, this is a fraction of a percent but it could happen! The process takes around 60 minutes.
Warning!*Users with cars MY07 and earlier may experience power drain issues after the upgrade. See the post “Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210,
Kan man gå direkt från min gamla Firmware till denna, eller måste jag ta de som kommit ut emellan först?
Under infon för Firmware 5269 står att alla version D och senare kan ha denna firmware...
Men på den första infon står att man kan ta 5269?
Please help me!
Är jag rätt ute med 5269 eller helt fel?
Evil
Tror du behöver aktivera servicemenyn om du inte kommer längre ( obs har jag för mej)
Vag-com(vcds) löser det
