Resultat 1 till 11 av 11
2008-06-14, 21:11 #1foffa2002Gäst
VW regerade på EDPS Malmby 2008
After last weeks 1st place at international http://www.Bugrun.com event i raced a local event with a new air port strip http://www.bilsport.se EDPS event with NO TRACK PREP what so ever.
And this is propably the most fun event ive ever done.
Everything from 1200hp skylines to 800Hp Volvos and hondas :thumbup:
I attended the FWD class and WON.
But ive propably reached my limit for my chassi setup
check this out and see what you think.
Now i got the consitency you told me to get and now i need to tune the chassie and add some more boost and visit a prep track
Best 1/8th mile MPH = 104.4mph
Best 1/4th mile MPH = 132.5mph
Chassie
0 TOE
0,3* camber
8,5* caster
Boost
started on 21psi on the first run and ended up on 26,5psi on the last
Pulled of some responce due to missfire.
added liner boost with gain for each run.
Tires
ET street 26x15x10,5
11,5psi seem to work the similar as 9psi
Weight
3150Lb
Hit revlimit on a bunch of runs with less mph/had some missfire due to incorrect boost seting.
So
Now i need to add 4-5psi more boost.
But the rear 300lb Eibach spings need to be changed for 750lb ones.
But i think that TOE might give me more gain .
How much TOE do you run ?
Time tree
2008-06-14, 21:22 #2
- Fredric Andersson
- 5407
- Finspång
- 952
Satan, boran e bra rapp !!!
Bara att grattulera !!
2008-06-14, 21:29 #3foffa2002Gäst
Fatta vad ballt på preppat på Action meet
Är sjukt sugen på en hög 10a
Filmer
http://www.youtube.com/watch?v=Rk5l8VfAPtU
http://www.youtube.com/watch?v=cR4_M8e1z5g
2008-06-14, 22:06 #4
- Jens
- Varberg
- 908
Både går och låter gutt!!! Grattis :-)
Jag hoppas på Henke i Gbg visseligen ;-) Ska du dit ?
2008-06-14, 22:11 #5foffa2002Gäst
2008-06-14, 22:14 #6
- Jens
- Varberg
- 908
Jaha ok.
Jo vi får göra det. Jag hjälpte han att ta ner lådan i torsdags kväll
Jo det verkar finns en del att ta av ;-)
2008-06-14, 22:22 #7foffa2002Gäst
2008-06-14, 22:26 #8
- Jens
- Varberg
- 908
"Hahaha"....tråkigt naturligvis!!, Det är han med den svarta golf 3?
nja så illa var det nog inte men det var inge bra om man säger så..
Puckarna var helt söndersmulade, och tryckplattan hade det blivit lite roliga spår i, "grand canyon"Senast redigerad av Mr dOhC den 2008-06-14 klockan 22:33.
2008-06-15, 12:39 #9BarbapappaGäst
Snyggt jobbat och grattis till de fina och jämna tiderna foffa!
Missade ju alla körningarna på strippen på bugrun, vad blev det för tider på mantorp?
2008-06-15, 12:44 #10jocke.wGäst
va faan...va du på BugRun Foffa???
Tråkigt....stod å kolla strippen på Lördagen å missa dig helt!?!?!
2008-06-15, 15:00 #11foffa2002Gäst
Körde bara söndagen.
Det blev 11.69 där på 1.65bar ladd
Landade på 1.85 nu i helgen.
Ska upp på 2bar
Ska justera chassie så kan det bli jäkligt ballt på mantorp =)
2.05 i 60fot ska kapas till ~1,75
0,3 blir minst 0,6-0,8 av från 11.75 =)
Om det nu håller på fullklistrat + uppför
Btw malmby är 3meter uppför jämfört med 7 meter på Mantorp.
Ser lite skumt ut på filmerna när bilen försvinner efter målgång på Malmby när man passera röver krönet )
