    foffa2002
    Över 600hk bromsat i bruksbilen
    Wow ....Talk about a nice way to spend 5 hours with 3 wheel changes
    All i can say is that im totaly exhausted after this.
    After having problems with the hub dyno at www.rri.se due to exedet wheel axle TQ we decided to go to www.Turbocenter.se .
    They use the normal type of rollers that most of us are used to.
    We used the roto-test lab dyno graph to double check the Turbocenter bench and it was dead on in every different boost we tested :thumbup:
    +- a couple of ponnies.
    Even showing a bit less then the World standard RRI lab bench.
    But never mind that.
    AND PLEASE read the entire post.
    Had serious problems with wheel spinn on the rollers and i will do a graph of what acctually happends to the TQ curve ~5000-6000rpm.
    AND ITS A 500HP RATED TURBO
    We tried to solve it but couldent get grip at that rpm ....sorry
    Even in 5th gear.
    Were the tires slip is visable at the RPM vs MPH line
    BTW the 02M handle 650NM in 5th :P :thumbup:
    Here is what it looks like wheel spinn vs no spinn.
    Started of in 4th gear and with 1.25 bar of boost test pull.
    And now keeping 1.25 with full responce vs the RRI graph it got more TQ but still keept the power to 7000rpm were we basicly decided to crank up some more .
    1.25 and 440WHP
    1.55bar and 480whp
    Some wheel spin but TQ curve look as good as ever.
    1.75bar and 521whp
    Here we started to get some serious problems with 5th gear
    TQ curve should ba as flat as in the graph before.
    foffa2002
    2.0 - 1.8bar and 540WHP
    Ok the final round.
    2bar at 4800rpm falling down to 1.8bar....turbo is totaly out of its range .......about in graph no:! :P
    And do i need to say tires did not hook
    But still a nice :thumbup:
    And here it is with some correction :laugh:
    Smothing vs rpm correction stage 9
    540Whp and 590Wheel NM
    ThomasTs avatar
    Thomas Thuresson
    Nacka
    Är det vid sådana här tillfällen som man brukar lägga in denna bild??!?
    Robert Samuelsson
    Oskarshamn
    600hk i bruksbilen?? Optimerat för snabba omkörningar o bra vrid vid släpvagnsdragning? Grymt! Blir det några events i år?
