Resultat 1 till 3 av 3
2007-05-15, 22:37 #1ZappAGäst
färdatorn till min gti mk1 -83
färdatorn till min gti verkar inte funka så bra ser bara klockan kan inte ändra den är detta nått vanligt fel eller vet nån en lösning på den ?
2007-05-15, 22:49 #2Bengan.UGäst
Hej.
Kanske kan vara till lite hjälp.
Försöka duger,heter det ju :-)
"- Trip computer
The classic hot hatch is notorious for problems with the trip computer. A
modern feature for its time, the GTi was fitted with a gizmo that tells you
lots of journey information including time, mpg and temperature. After
many years of faultless service, these computers tend to suffer from an
electronic 'hiccup'.
Instead of displaying the usual range of trip information, the tiny screen
either shows just some horizontal lines at the bottom or it goes
completely blank.
This same 'hiccup' also often occurs if the battery is flattened or
disconnected. Instead of displaying the usual range of trip information,
the tiny screen either shows just some horizontal lines at the bottom or it
goes completely blank! In the worst case this will mean a replacement
unit but there is also a quick fix worth trying (you will need a happy
helper for this job):
ALWAYS TAKE CARE WHEN DEALING WITH BATTERIES/ELECTRICS
* Disconnect the battery.
* Hold down the MFA button.
* Reconnect the battery.
* While still holding down the MFA button, turn on the ignition,
release the button and turn off the ignition.
* Hold down the MFA button again, turn on the ignition and
release the button.
You should now have a correctly working display. It has been known for
the display to jump into life halfway through the process. If this happens,
you can congratulate yourself and stop right there, for it has been
known for the computer to 'hiccup' again if the process is continued
after it comes back to life! "
MVH/Bengan.U
2007-05-16, 00:05 #3ZappAGäst
ska prövas imorn tack bengan
