Resultat 1 till 2 av 2
    okt 2020
    Andreas Wahlsten
    Fel kod p0469 på Passat tid 140hk -12
    har fått felkod p0469 på min passat men är osäker på vilken givare jag skall byta, finns 1st till turbon och 1st till avgaserna.
    någon som har en idé?
    Gäller en passat tid 140hk 2012
    Är inte den koden för någonting kopplat till tankventilationen?
    Och naturligtvis har du testat att radera den innan du bekymrar dig vidare....
    • P0469 code definition
      The P0469 code indicates that there is a problem within the vehicle’s evaporative (fuel) system, and that a portion of the system is not working correctly. Specifically, this code indicates a problem with the purge flow sensor. However, as this is a generic code, the actual definition can vary from one vehicle to another. For instance, for GM vehicles, a P0469 code is “evap flow during non-purge condition,” and for many Asian imports, it is “evap system high purge flow.”What the P0469 code means
      The P0469 code means there is a problem somewhere within the vehicle’s evap system. This may or may not actually be related to the purge flow sensor or solenoid. It could also apply to a number of other system components, including the following:
      • Gas cap
      • Charcoal canister
      • Fuel line
      • Flow sensor
      • Vacuum line
      • Fuel vapor hose
      What causes the P0469 code?
      The modern evap system is complex, and the P0469 code can be caused by a number of different problems. These can include the following:
  1. Fel kod p0236 Passat 2,0 tdi 2010
    Av JanneVTR i forum VW-forum
    Svar: 16
    Senaste inlägg: 2020-09-07, 19:16
  2. Svar: 0
    Senaste inlägg: 2015-08-17, 14:13
  3. Svar: 2
    Senaste inlägg: 2013-10-25, 06:36
  4. behöver hjälp med eraser fel-kod VW
    Av H.R i forum VW-forum
    Senaste inlägg: 2013-04-20, 23:50
  5. Fel kod i gamma radion nu låst?
    Av Thullen i forum VW-forum
    Senaste inlägg: 2007-05-24, 06:43
