2019-05-17, 23:14 #1
- okt 2008
- soyd
- Örnsköldsvik
- 345
Bytte CANBUS gateway fick följande felkoder (MK5 GTI)
Hej installerade min nya CANBUS gateway i kväll här, fick dock följande felkoder:
Bytte från: 1K0 907 530 K
Till: 3C0 907 530 Q
På en Golf GTI 2007 (Edition 30)
Några idéer ?
Kod:Friday,17,May,2019,21:39:47:41854 VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86 VCDS Version: 18.9.1.0 Data version: 20190114 DS296.0 www.Ross-Tech.com Dealer/Shop Name: Volkswagen Sverige Workshop Code: 031 45634 074342 VIN: XXXXXXXXXXXXXXXXX License Plate: XXXXXX Mileage: 77220km Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1K (3C0) Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 VIN: XXXXXXXXXXXXXXXXX Mileage: 77220km 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Cannot be reached 1100 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels:. 06F-907-115-AXX.clb Part No SW: 1K0 907 115 L HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI 02 3$30 Revision: 5BH16--- Serial number: VWZ7Z0F8230696 Coding: 0403004318070160 Shop #: WSC 00191 264 15243 VCID: 2F552DBBBEBE323274-807A No fault code found. Readiness: 0000 0001 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0004738 Shop #: WSC 01279 785 00200 VCID: 73DDE1CB121656D2D0-8026 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ Component: ClimatronicPQ35 090 0909 Revision: 00090016 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 70D7EEC763006DCA2D-8024 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE Component: Bordnetz-SG H52 2002 Revision: 00H52000 Serial number: 00000006464033 Coding: E58F8F2700041500471400001400000000097F075C0001 Shop #: WSC 00000 785 00200 VCID: 6CEFFAB74F28892A11-8038 Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB Component: Wischer 271006 020 0501 Coding: 00038805 Shop #: WSC 00000 Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB Component: RLS 071206 020 0105 Coding: 00208933 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: 37 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD0XCHSA Coding: 0013111 Shop #: WSC 01269 785 00200 VCID: 3D4907F364D2D0A2F6-8068 Subsystem 1 - Serial number: 6332MSME152C7C52H Subsystem 2 - Serial number: 6342MSME15446947C Subsystem 3 - Serial number: 6352QSME19771723E Subsystem 4 - Serial number: 6362QSME1A642749L No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC Component: Lenksäulenmodul 636 0070 Coding: 0000042 Shop #: WSC 01279 785 00200 VCID: 74DFE2D7171851EAC9-8020 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1K6 920 863 HW: 1K6 920 863 Component: KOMBIINSTRUMENT VDD 1610 Revision: V0003000 Serial number: VWZ7Z0F8230696 Coding: 0005103 Shop #: WSC 45634 031 74342 VCID: 6EEBF0BF79347B3A3F-803A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb Part No SW: 3C0 907 530 Q HW: 3C0 907 951 Component: J533 Gateway H13 0172 Revision: H13 Serial number: 3640P17520034B Coding: E9801F06500202004000 Shop #: WSC 45634 031 74342 VCID: 2F552DBBBEBE323274-807A 2 Faults Found: 02638 - Enabling Steering Column Lock 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 1 Fault Frequency: 9 Reset counter: 1 Mileage: 77217 km Time Indication: 0 00474 - Control Module for Immobilizer 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 1 Mileage: 77221 km Time Indication: 0 ------------------------------------------------------------------------------- Address 25: Immobilizer Cannot be reached ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb Part No SW: 1T0 035 680 D HW: 1T0 035 680 B Component: RNS-MID H03 3970 Revision: AB001001 Serial number: -------------- Coding: 00010000010000100000 Shop #: WSC 01279 758 00200 VCID: 2F552DBB7EBE323274-807A No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1K0 959 701 M HW: 1K0 959 701 M Component: Tuer-SG 005 0981 Coding: 0000052 Shop #: WSC 01279 785 00200 VCID: 384716E74BF0F58A25-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb Part No: 1K1 909 144 L Component: EPS_ZFLS Kl.074 H07 1806 Shop #: WSC 00000 028 00001 VCID: 345F22D7579811EA09-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb Part No: 1K0 959 433 AJ Component: KSG 0401 Coding: 00D802087F2D8405484A03E010CC Shop #: WSC 01279 785 00200 VCID: 78C7D6E70B70358AE5-802C Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 3C0-035-456.clb Part No: 1K6 035 456 A Component: 08K Audioverst. 0005 Revision: 00003000 Serial number: 00000000104431 Shop #: WSC 00000 000 00000 VCID: 2A633CAF855C571AA3-807E No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1K0 959 702 M HW: 1K0 959 702 M Component: Tuer-SG 005 0981 Coding: 0000052 Shop #: WSC 01279 785 00200 VCID: 394113E370FAEC82DA-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels:. 1T0-035-680.clb Part No SW: 1T0 035 680 D HW: 1T0 035 680 B Component: RNS-MID H03 3970 Revision: AB001001 Serial number: -------------- Coding: 00010000010000100000 Shop #: WSC 01279 758 00200 VCID: 2F552DBB7EBE323274-807A No fault code found. End-------------------------(Elapsed Time: 01:40)--------------------------
Senast redigerad av soyd den 2019-05-17 klockan 23:30. Anledning: Jag missade att lägga denna i VCDS kategorin, sorry flytta om så behövs!
2019-05-18, 09:59 #2
Du kan inte använda en Passat Gateway i en Golf!
Har en 1k0 Q gateway, ifall du behöver.
2019-05-18, 11:04 #3
- okt 2008
- soyd
- Örnsköldsvik
- 345
2019-05-18, 13:49 #4
Jag behövde aldrig byta gatewayen på min ED30 när jag slängde in RNS510:an. Den var tillräckligt ny för att funka. Problemet skulle väl vara att den kan dra ur batteriet om den är för gammal. Det har jag aldrig haft några problem med så jag antar att det faktiskt var ok.
2019-05-18, 22:54 #5
Inte så insatt i Golf´s gateway, men till Passat är det väl N som (uppdaterad) klarar senaste firmware till RNS510.
Lägger man in firmware som är äldre än 2008 på RNS så fungerar den med det gamla CAN-bus "systemet".
2019-05-19, 18:26 #6
- okt 2008
- soyd
- Örnsköldsvik
- 345
Det var samma för mig back in 2008:a då jag installerade RNS510:a också! Men nu när jag byter mot en RCD330P så kommer det mest troligt inte att lira som jag fattat det!..
Det kan nog stämma.. jag har också för mig att den/de första modellerna av RNS510:an var kompatiblet med det äldre canbus systemet så där av lirar det nog för mig och vfr!
Undra om jag ska försöka få tag på Q eller AD versionen
1K0 907 530 Q
1K0 907 530 AD
Jag antar att det räcker med Q ser ut som att AD är för MK6 men verkar även lira på MK5:an ?
/mvh soyd
2019-05-20, 14:36 #7
- okt 2008
- soyd
- Örnsköldsvik
- 345
Följer upp lite för allmänna info om det är någon som söker samma infon någon gång fram över!
1K0 907 530 AD är i skrivande stund senaste versionen för bl.a. Golf MK5/MK6 Kommer säkert inte komma någon fler revisioner på den då bilarna inte längre tillverkas osv..
Dock så går det inte just nu att få tag på den som ny reservdel hos VW finns inte i lager i Sverige eller Tyskland (Populär reservdel...). De finns nya från Kina på ebay men enligt "vissa" källor på nätet så "kan" det vara kopior..! (Jag vågar inte chansa och köra med en kopia..) + att jag orkar inte vänta 2 månader för att spara 500kr..
Hur som jag hittade en på lokala skroten som var plockad ur en 2010:as Golf med 373mil på mätaren!
mvh soyd
Gjorde felkods avläsning på min Golf GTI -07:a hittade följande felkoder:
Av soyd i forum VCDS/OBDeleven/Carista/VCP analysverktygSvar: 5Senaste inlägg: 2013-06-26, 10:50 -
Felkoder golf gti mk5
Av Mickeelfstedt i forum VW-forumSvar: 6Senaste inlägg: 2013-06-16, 17:44 -
motor bytte golf2 1,8 gti 8v till motor från golf 3 93årsmodell
Av eckim82 i forum VW-forumSvar: 1Senaste inlägg: 2011-02-21, 17:47 -
Fick nya sommarskor till min MK5 GTI :)
Av poppen_83 i forum ProjektforumSvar: 0Senaste inlägg: 2010-06-19, 00:19 -
Bytte växellådsolja idag, fick jag ut mer än jag borde?
Av RasmusC i forum VW-forumSvar: 3Senaste inlägg: 2007-07-04, 09:23
