    apr 2013
    Pether
    Finspång
    Bromsskivor Golf 4 variant
    Dax för bromsbyte på droskan. Men de verkar vara en djungel. Nån som har koll på vilka skivor de ska va fram respektive bak?
    Mk4 Variant 1,6 16v -02
    jun 2010
    Andreas
    Lyckeby (Karlskrona)
    PR koderna i serviceboken ellet vit etikett bagerumsgolv bör kunna ge en en vägledning
    https://www.autoteileservice24.de/vw...cheibe_l100032
    apr 2013
    Pether
    Finspång
    Den vita etiketten sa inget om vilken storlek på bromsskivor tyvärr...
    Namn:  19022506_10213946834613859_646413339_o.jpg
Visningar: 241
Storlek:  201.9 KB
    X1D = National sales program Sweden
    B0H = Component parts set, complying with vehicle type for Sweden, various parts
    C6E = Steel wheels 6J x 15 Offset 38
    G0C = 5-speed manual transmission
    H6S = Tires 195/65 R15 V
    J1L = Battery 280 A (60 Ah)
    D3H = 4-cylinder gas. engine 1.6 L/77 kW (16V)with multi-point injection Base engine is T27/TL0/TT0/TV5
    1AC = Anti-lock brake system (ABS)
    1G2 = Steel spare wheel with original equipment tires
    1MP = Steering wheel for air bag system
    1ND = Full wheel covers
    5RQ = Right exterior mirror: convex
    5SL = Left exterior mirror: aspherical
    T27 = 4-cylinder gasoline engine 1.6 L unit 036.L
    0BC = Rear stabilizer
    3S2 = Black roof rails
    3U2 = Sliding trunk cover
    QG1 = Service interval prolongation
    QG3 = Without service interval prolongation
    8GD = Alternator 90A
    8L3 = Roof antenna
    1H0 = Without proportioning valve
    1KP = Disc brakes, rear
    1LS = Front disc brakes with integrated adapter
    3YQ = Door pockets without insert mats
    G08 = Front shock absorption
    0GG = Emission standard EU4
    4UE = Air bag for driver and front seat passenger
    4X1 = Side air bag front
    4R0 = Mechanical window regulator
    4F1 = Central locking system
    N4C = Fabric seat covering
    5MA = Decorative inserts
    8RM = 8 speakers (passive)
    2JB = Standard bumpers
    E0A = No special edition
    0AE = Front stabilizer
    1JH = Rear shock absorption
    L16 = Suspension range 16 installation control only, no requirement forecast
    0YZ = Without determination of weight categoryfor rear axle
    Löste de. 1LS = 280mm 1KP = 232mm http://shop.ahw-shop.de/vw-teile/gol...remsanlage?p=1
    jun 2010
    Andreas
    Inga kostigheter alls
    1KP = Disc brakes, rear = Skivbroms bak
    Tjocklek 9mm ytterdiameter 232mm
    1LS = Front disc brakes with integrated adapter = skivbroms fram
    Tjocklek 22mm ytterdiameter 280mm
    bara ut å mäta för att verifiera
  1. Svar: 0
    Senaste inlägg: 2016-11-14, 14:44
  2. Golf R bromsskivor
    Av pp3 i forum VW-forum
    Senaste inlägg: 2013-12-11, 14:01
  3. Svar: 5
    Senaste inlägg: 2011-02-21, 09:43
  4. Svar: 18
    Senaste inlägg: 2009-06-03, 01:14
  5. Slitsade bromsskivor golf G60
    Av Dave the brave i forum VW-forum
    Svar: 6
    Senaste inlägg: 2007-05-24, 22:39
