Resultat 681 till 700 av 1577
Ämne: Golf generation 8
2020-12-05, 14:44 #681
- jan 2012
- Magnus Wide
- Uppsala *Golf MK8R*
- 1 891
2020-12-05, 16:06 #682
- Philip
- 229
2020-12-05, 19:18 #683
- jan 2012
- Magnus Wide
- 1 891
2020-12-05, 23:21 #684
Bromsarna. Som du skriver, S3:an har samma ok som Golf 7 GTIPP/R och S3 8v (föregångaren). Det är enkolvsok, (som funkar kanonbra ).
Bromsok Golf R mk7:
Bromsok S3 8Y (nya S3), identiskt med bilden ovan:
R mk8 bromsar, helt annat ok:
http://www.gtiklubben.nu/forum/showt...l=1#post257491
Det hade jag missat, tog för givet att det var samma som nya R.Senast redigerad av Peter-C den 2020-12-05 klockan 23:32.
2020-12-06, 15:59 #685
- jan 2012
- Magnus Wide
- 1 891
2020-12-07, 15:33 #686
- jan 2012
- Magnus Wide
- 1 891
Första provkörningen av Ren..... F***n verkar galet trevlig .
https://www.autocar.co.uk/car-review...-r-2021-review
Should I buy one?
On first impressions, the new R not only lives up to lofty expectations, but exceeds them.
Yes, it’s quick; perhaps not at the level of the Mercedes-AMG A45, but it certainly has the measure of its key rivals, the Audi S3, BMW M135i and Mercedes-AMG A35 4Matic.
However, it is also a terrifically well balanced car whose traction and exploitability is every bit as impressive as the tractability and superb manners of its reworked engine. For sheer performance and all-season appeal it rises above the new Golf GTI, and comfortably so.
Admittedly, to properly gauge its handling in the dry, we’ll need more favourable weather conditions – and perhaps we’ll get them when we test this car in the UK.
For now, what we can say is that the Golf R’s clever chassis technology brings a broader range of characteristics to the table than before. There’s greater compliance and overall comfort at the more relaxed end of the scale, but added response and even more impressive body control in the more sporting settings than its highly admired predecessor.
2020-12-07, 18:28 #687
Lovorden haglar över R:en i Autocars utvärdering !
Dock anmärkning på långsam respons från infotainmentsystemet, ej R relaterat. Uppgradering SW i närtid?
2020-12-08, 08:08 #688
- jan 2012
- Magnus Wide
- 1 891
2020-12-08, 08:41 #689
- 2 020
2020-12-08, 08:47 #690
- 2 020
Jag menar att den fortfarande ser ut om en Golf som kostar från 250tkr eller vad det nu kan vara. Golfen är ju på riktigt en Folkvagn för kategorin du räknar upp så ur det perspektivet är 687.200kr befängt - för en folkvagn.
Finns det nu någonstans att lägga laddkablarna?
2020-12-08, 09:56 #691
- jan 2012
- Magnus Wide
- 1 891
Nja, kan det vara så illa som medvetet ... Känns som VW har lite mjukvaru problem just nu. Bara se ID3 som varit galet dålig...men där ska det visst vara mkt bättre nu...
Får ju hoppas man inte köper en Golf för 500 000 + och info systemet laggar som en gammal android platta från 2010 hemma
2020-12-08, 10:00 #692
- jan 2012
- Magnus Wide
- 1 891
Håller med rätt galet att man närmar sig 700k för en Golf, vi snackar ju Porsche instegs priser nu . Kan säga efter klämt på en 918 så är det en hel annan liga i kvalité mm...
Jo man kan bråtta ner den där skitiga och otympliga kabel under golvet lite halvsmidigt ...
2020-12-08, 10:43 #693
- 5 322
Är ju inget unikt för VW Golf, enklaste Volvo V60 ser också ut som toppmodellen, för gemene man, trots rejäl prisskillnad. Samma sak med Mercedes A-klass. Teknikinnehållet är däremot radikalt annorlunda.
Laddkablar: jag rekommenderar att använda laddbox med fast kabel.
2020-12-08, 11:36 #694
- 1 898
2020-12-08, 11:44 #695
- 5 322
Det finns offentliga laddstolpar (långsamladdare) med och/eller utan fast laddkabel. Utan fast kabel är det absolut vanligaste. När fast laddkabel saknas använder man sin egen typ 2 kabel som ansluts mellan laddstolpens uttag och bil. Laddhybrid (PHEV) laddar man inte i snabbladdare (som alltid har fast laddkabel), som man kan göra med elbil (BEV). Men jag vill nog påstå att laddmöjlighet hemma eller minst på exempelvis arbetsplats parkering (plats där man uppehåller sig en större del av dygnet) är en förutsättning för att det ska vara meningsfullt med laddhybrid. Hemma ska man naturligtvis välja en laddbox med fast kabel.
2020-12-10, 12:11 #696
- jan 2012
- Magnus Wide
- 1 891
"Första" med provkörningen med Clubpsporten!.
De tycker den är rätt ok, fast den kostar så lika Ren i England!. Vi har bra mkt bättre pris på denna i Sverige med samma utrustning!
Där det skiljer typ 80 000 i Sverige mot bara 22 000 i England...Mellan R och Clubsport
Läckra Bromsar!
https://www.autocar.co.uk/car-review...rt-2020-review
2020-12-10, 12:58 #697
- 5 322
Auto Bild körde redan i oktober https://www.autobild.de/artikel/vw-g...-18481547.html
2020-12-10, 17:53 #698
Synd bara att denna lider av samma "fel" som tidigare MQB bilar med tvådelade bromsskivor, nämligen att det sitter en vänsterskiva på båda sidorna av bilen (hålmönstrets riktning avslöjar detta). Hålmönstret i sig spelar ingen roll men som man kan se i bilen ovan är "kylflänsarna" i dessa skivor vinklade och på högersidan av bilen hamnar dessa i fel vinkel.
Undrar om vi nånsin kommer få se en Golf med fabriksmonterade fasta bromsok istället för glidande ok. Det är ju nåt som hittar på konkurrenterna såsom BMW M1xx, Mercedes-AMG A-klass, Honda Civic Type-R, Ford Focus RS (medan den fortfarande fanns), och Renault Mégane R.S. Förekommer även på mindre modeller som Toyota Yaris GR och gamla Yaris GRMN. Även inom VAG koncernen finns ju Seat/Cupra med lång tradition av att erbjuda fasta ok på León, fanns till och med som tillval till Ibiza Cupra en gång i tiden.Kör Polo R WRC -14
2020-12-10, 18:30 #699
- jan 2012
- Magnus Wide
- 1 891
Japp, därför man gjorde "" . Men den var jobbigt tysk , google translate är lite knackigt
Ja så sant!, men ett steg fram emot vad man tidigare fått
Däremot så skulle man vilja ha dessa, som är ett tillval på Cupra Formenator..
2020-12-12, 13:02 #700
- jan 2012
- Magnus Wide
- 1 891
Nya Turbon i Gen 4 888 motorn verkar funka!. Snabbare än en 280hk Fård!
Man kanske skulle beställa en vanlig GTI, så man kan få den den där jäkla dragkroken oxå!
ET frågor Golf generation 7
Av Marcus i forum VW-forumSvar: 9Senaste inlägg: 2017-03-12, 09:35 -
Bränsleförbrukning Golf R generation 7
Av Peter56 i forum VW-forumSvar: 10Senaste inlägg: 2016-12-31, 12:34 -
Generation VW Golf - kampanjen från lanseringen av Golf generation 4
Av Marcus i forum Bilder och VideosSvar: 0Senaste inlägg: 2016-09-21, 09:38 -
VW Golf - generation 8
Av Marcus i forum VW-forumSvar: 1Senaste inlägg: 2014-12-05, 11:44 -
Golf GTI generation 7 - modellvideo
Av Marcus i forum Bilder och VideosSvar: 0Senaste inlägg: 2013-07-20, 08:23
