2015-06-03, 15:47 #1
- maj 2015
- Thomas Suominen
- Nykvarn
- 16
Körde felsökning och hittade flera felkoder, hur åtgärda?
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
77-Telephone -- Status: Malfunction 0010
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P102230402
Coding: FDA37F46000E02002002
Shop #: WSC 05314 123 12345
VCID: 2F556B53BE00E759C75-807A
2 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0305
Revision: 13101005 Serial number: 0000475400
Coding: 0000B5
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 65F9C97B647C6D09FD9-8030
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001293120
Coding: 000090
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 142063 km
Date: 2015.06.02
Time: 18:19:57
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 040 0166
Revision: 00000001 Serial number: VWZ1Z3K6360926
Coding: 0500040004
Shop #: WSC 05314 000 00000
VCID: 65F9C97B6C7C6D09FD9-8030
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
Date: 2015.06.02
Time: 22:56:19
00821 - Antenna 2 for Radio (R93)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
Date: 2015.06.02
Time: 22:56:19
03138 - Input AUX IN
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 89
Mileage: 142063 km
Time Indication: 0
Date: 2015.06.02
Time: 18:12:09
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H15 4217
Revision: 1B001001 Serial number: 00000000000000
Coding: 0A11000000010101
Shop #: WSC 03743 444 00001
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3C4F4C1FB7760CC1727-8069
7 Faults Found:
9455635 - Telephone Microphone
B1048 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 88
9457427 - Left audio channel for speech/telephone
B104F 13 [008] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 88
9457171 - Right audio channel for speech/telephone
B104E 13 [008] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 88
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
12718592 - Steering Column Control Module
U0212 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
0022 - Radio
U1066 00 [008] - No Communication
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
End-------------------------(Elapsed Time: 02:13)--------------------------
2015-06-03, 16:14 #2
Har detta något med din stereo/HF-uppgradering att göra som du skriver om i annan tråd? Blev det i samband med det, eller har det bara kommit plötsligt?
2015-06-03, 17:44 #3
- maj 2015
- Thomas Suominen
- Nykvarn
- 16
Jo, nollade koderna idag. Tänkte inte på att det står tidpunkter, men uppgraderade stereon med blåtand igår kväll och måste kommit i samband med detta. Sen var det en felinställning som jag ändrade. En felkod kvar och det var tydligen en trasig blinkers i spegeln.
2020-11-21, 16:02 #4
- jan 2015
- K S
- Norrköping
- 90
Vad hade du för lösning på b11fd? Har en bekant där höger blinkers i spegeln slutade att fungera på en Polo 2015 efter att fukt kommit in. Bytte blinkersglaset men fungerar ändå inte. Felkod B11FD 13. Behöver man koda om något efter bytet av blinkersglas? //Kristian
2020-11-21, 23:42 #5
- 2 015
Årets trådlyft?
Du menar kanske att du bytte blinkersinsatsen? Spegeln har väl inget med blinkersen att göra.
2020-11-22, 10:31 #6
- jan 2015
- K S
- Norrköping
- 90
Felsökning/Hjälp att tyda felkoder Golf mk4 GTI
Av LimMet i forum VW-forumSvar: 1Senaste inlägg: 2014-08-16, 22:11 -
Gjorde felkods avläsning på min Golf GTI -07:a hittade följande felkoder:
Av soyd i forum VCDS/OBDeleven/Carista/VCP analysverktygSvar: 5Senaste inlägg: 2013-06-26, 09:50 -
VCDS, äntligen hittade en och här är mina erfarenheter
Av RGerman i forum VCDS/OBDeleven/Carista/VCP analysverktygSvar: 14Senaste inlägg: 2012-11-07, 22:26 -
Styrservon läcker, hur åtgärda?
Av rosengren_ i forum VW-forumSvar: 5Senaste inlägg: 2011-04-06, 22:17 -
Omöjligt fel att åtgärda.. Ryker, blöddrar och tappar kraft.
Av Alpine i forum VW-forumSvar: 28Senaste inlägg: 2010-05-12, 14:26
