Resultat 1 till 9 av 9
2014-07-30, 23:00 #1
- jun 2007
- Peter S.
- 4681
- 295
Felkod elektrisk handbroms passat 3c 2009
Fick häromdagen felmeddelande "parking brake failure, owners manual" och en orange symbol med ett "P" med streck över tänds. Handbromsen verkar fungera som den ska.
Läste ut nedan felkod med VCDS:
VCDS version: AER 12.12.0
Adress 53: Parkeringsbroms Labels: AER\5N0-907-801.clb
Styrenhet artikelnr: 3C8 907 801 A HW: 3C8 907 801 A
Komponent och/eller version: J540 EPB3 VW-10498 0003
SW-kodning: 0000057
Verkstadskod: WSC 05311 000 00000
VCID: 2867C5749B75025EFC3-807D
1 fel funnet:
02845 - Funktionsindikering i kombiinstrumentet (!)
007 - kortsl. till jord - Fellampa(MIL) tänd
frysta data:
Felstatus: 11110111
Felprioritet: 2
Felfrekvens: 2
Reset-räknare: 152
Mätarställning: 128218 km
Tidsindikering: 0
Datum: 2063.14.12
Tid: 12:36:29
frysta data:
Spänning: 11.70 V
Räkna/re: 78
Hastighet: 0.0 km/h
Hex-värde: 0x1271
Hex-värde: 0x0001
Hex-värde: 0x1010
Läser man på ross tech:
http://wiki.ross-tech.com/wiki/index.php/02845
02845 - Function Display in Instrument Cluster (!)
02845 - Function Display in Instrument Cluster (!): Short to Ground
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Red Brake light or Electro-Mechanical Parking Brake (EPB) light ON
Auto-Hold function in Electro-Mechanical Parking Brake (EPB) disabled
Possible Causes
When found in the Electro-Mechanical Parking Brake (EPB) control module this may be caused to a software problem as noted below.
Possible Solutions
When found in the [53] - Parking Brake control module on the VW Tiguan : NAR (North America Region) vehicles refer to TSB 46-09-03 -or- TPI 2021855
RoW (Rest of World) vehicles refer to TPI 2021008
When found in the [53] - Parking Brake control module on the VW Passat or VW Passat CC RoW (Rest of World) vehicles would refer to TPI 2021874
Vad innebär TPI 2021874 ?
Någon som haft liknande fel?
2014-08-01, 17:21 #2
- Mattias
- 2 135
TPI = Technical Product Information (VWs egna reparations och verkstadsinformation)
länken nedan kräver login.. och det är något som alla ackrediterade VAG-handlare borde ha.
åk till din lokala VAG-handlare och hör efter vad det står i just den TPIn som du har numret på där.. så får du reda på vilken åtgärd som VW rekkomenderar.
(dom kan vara lite kinkiga/ovilliga att lämna ut informationen.. då det egentligen är råd till verkstäderna hur dom BÖR lösa kända problem på kundbilar..)
https://erwin.volkswagen.de/erwin/showHome.do
2014-08-07, 11:06 #3
- jun 2007
- Peter S.
- 4681
- 295
Tack för infon Mattias!
Dock har jag varit i kontakt med 2 olika VW och TPI 2021874 finns inte när dom söker !?
Inte heller TPI 2021855 eller TPI 2021008 för Tiguan finns.
Ross tech verkar hänvisa till felaktiga nummer tyvärr & båda ställena vill istället ta in bilen för felsökning...suck.
Det känns verkligen som ett mjukvarufel då handbromsen fungerar utmärkt.
2014-08-13, 15:45 #4
- jun 2007
- Peter S.
- 4681
- 295
Finns det något man skulle kunna testa i VCDS för att lösa detta?
Det enda jag gjort är att tagit bort felkoden några gånger men den kommer tillbaka direkt.
Alla tips är välkomna
2014-08-13, 21:09 #5
- jul 2014
- Johnnie Andersson
- Tibro
- 5
Lossa styrdonet till handbromn och låt det ligga strömlöst över natt. Lycka till!
2014-08-13, 23:06 #6
- jun 2007
- Peter S.
- 4681
- 295
2014-08-14, 17:33 #7
- jul 2014
- Johnnie Andersson
- Tibro
- 5
Under mittkonsolen
2014-09-29, 15:45 #8
- jun 2007
- Peter S.
- 4681
- 295
Lite återkoppling på detta:
Hade båda batterierna av ca 30 min, hjälpte inte.
Hade även bort styrdonet, hjälpte inte.
Ny mjukvara i styrdonet fungerade inte heller (som jag läst på en del forum verkar lösa problemet)
Fick konstaterat fel i styrdonet hos VW, är nu utbytt - problemet löst!
2014-09-29, 18:00 #9
Kanon att du återkopplar och talar om lösningen!
Passat 3C 2009 - byta ställmotor
Av Mulder-_- i forum VW-forumSvar: 25Senaste inlägg: 2018-01-15, 19:13 -
Passat 3C 2009 - fel höger elspegel
Av Mulder-_- i forum VW-forumSvar: 2Senaste inlägg: 2014-04-16, 20:55 -
Passat 3C 2009 - byta relä
Av Mulder-_- i forum VW-forumSvar: 8Senaste inlägg: 2014-03-01, 22:48 -
Byte bromsbelägg bak, passat 3c 2009
Av Mulder-_- i forum VW-forumSvar: 6Senaste inlägg: 2013-10-26, 19:46 -
Elektrisk kylfläkt/slavfläkt AC Passat -98!!!
Av crillez i forum VW-forumSvar: 2Senaste inlägg: 2009-03-21, 10:51
