VCDS
Sidan 2 av 2 FörstaFörsta 12
Resultat 21 till 24 av 24
  1. #21
    Arod
    Kod:
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
       Component: Lenks.Modul   H03 0004
       Revision: --------    Serial number: 90372KBM001WH
       Coding: 0000FF
       Shop #: WSC 06335 000 00000
       VCID: 44875BE3C7DE633EFFF-8011
       Component: E221 - MFL  H02 0003
    1 Fault Found:
    00895 - Cruise Control Switch (E45)
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 99
                        Mileage: 143548 km
                        Time Indication: 0
                        Date: 2014.06.14
                        Time: 12:44:08
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
       Component: KOMBIINSTR.   H20 0255
       Revision: 00100000    Serial number: CIY454TC9
       Coding: 0315080002000008010000
       Shop #: WSC 12345 123 12345
       VCID: 2E53194B7952F96E39B-807B
    No fault code found.
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G09B2684BA
       Coding: 00CF07
       Shop #: WSC 02391 823 56573
       VCID: 50AF67B303A68F9E4B7-8005
       Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
       Component: J367-BDM  H07 0125
       Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
       Component: J532_DCDCStab  H15 0038
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009702295
       Coding: 011C02204000410001
       VCID: 458146E7CCE45A36E81-8010
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0326
       Revision: 00002001    Serial number: 0124388724
       Coding: 011A0620003904400020013680000000
       VCID: 810912F7184C3616149-80D4
       Subsystem 1 - Part No: 8K0 951 177
       Component: DWA-Sensor  H02 0040
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009683702
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
       Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0100
       Revision: 00000003    Serial number: 00000000510162
       Shop #: WSC 00000 000 00000
       VCID: 34670B23977ED3BE4FF-8061
    Address 55: Xenon Range        Labels: 8K0-907-357.clb
       Part No: 8K5 907 357 A
       Component: Dynamische LWR  H01 0010
       Revision: 00000001    Serial number:
       Coding: 0000004
       Shop #: WSC 02145 785 00200
       VCID: 387F3F134B1637DE637-806D
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Component: Concert3      H05 0310
       Revision: 00000008    Serial number: AUZ5Z6I1319793
       Coding: 05000482040185000159070000
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
    1 Fault Found:
    03138 - Input AUX IN
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 98
                        Mileage: 143548 km
                        Time Indication: 0
                        Date: 2014.06.14
                        Time: 12:34:22
    Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102437278
       Coding: 010C02204000210001
       VCID: 428B5DFBDDCA6D0ECD3-8017
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102436300
    No fault code found.-
  2. #22
    Moderator
    Henrik.Ms avatar
    apr 2007
    Henrik M
    Norrland
    Felet på 01 och 16 hänger mest troligt ihop med varandra.
    Kontrollera som jag tidigare skrev att GRA (Farthållare) är aktiverat i motorstyrdonet.
    Felet på 56 (Radio) brukar man få om man kodar fel och kodar att radion har AUX fast den inte har det.
    Den ligger och övervakar AUX ingången på radion fastvden inte finns/är aktiv.
    Koda bort AUX på radion och se vad som sker om du INTE har en AUX ingång i bilen.
    Annars kan du strunta i den felkoden.
    Skrivet på forumspringaren.
    VW Golf 7 -16
    VW Jetta 2 -85
    Yamaha XV950R -15
  3. #23
    Arod
    Har haft farthållare hela tiden och det har funkat tills jag bytte släpringen. Kollade 01 och farthållaren var aktiverad som den skulle.
    Ang. aux så har jag det så det är nog inget att bry sig om.
    Försöker också koda 77-telephone för multiratt genom denna kod 0011400 men den vill inte acceptera. Vet du kanske nått om den?
    Det är antagligen så att jag ska kunna använda knappen med munnen på ratten om man ska kalla den det.
  4. #24
    Moderator
    Henrik.Ms avatar
    apr 2007
    Henrik M
    Norrland
    Kommer inte på nått annat för tillfället , förutom det jag skrivit.
    VW Golf 7 -16
    VW Jetta 2 -85
    Yamaha XV950R -15
  1. Svar: 2
    Senaste inlägg: 2010-07-30, 18:10
  2. BMW ägare som vill köpa ny GTI
    Av samuel2 i forum VW-Forum
    Svar: 11
    Senaste inlägg: 2010-06-05, 09:42
  3. Kylfläkt vill inte fungera
    Av Putsarn i forum VW-Forum
    Senaste inlägg: 2008-07-21, 21:17
  4. Svar: 7
    Senaste inlägg: 2008-06-29, 23:34
  5. Helljuset vill inte funka ?
    Av Alexander i forum VW-Forum
    Senaste inlägg: 2008-01-24, 21:20
