Resultat 1 till 17 av 17
    Jan Axelsson
    Uppgradera min RNS510 osäker om jag väljer rätt Firmware...
    Tänkte uppgradera min RNS510 men är osäker om jag väljer rätt Firmware...
    Har detta nu...
    Namn:  bild 1.JPG
Visningar: 1514
Storlek:  107.4 KB
    Namn:  bild 2.JPG
Visningar: 1388
Storlek:  114.9 KB
    Namn:  bild 3.JPG
Visningar: 1379
Storlek:  103.3 KB
    Namn:  bild 4.JPG
Visningar: 1230
Storlek:  108.0 KB
    Namn:  bild 5.JPG
Visningar: 1317
Storlek:  108.5 KB
    Nu till frågan..
    På MY-GTI.Com står det följande.
    HW Vehicle: 0xC201 – HW Radio: 0004
    C6/C7
    1T0 035 680 B (1T0035680B)
    Firmware version (when hardware last produced): 1300
    Firmware version (unmodified releases): 1300
    Firmware version (modified releases): 5269
    Sedan under länken till Firmware 5269 står följande..
    Volkswagen RNS 510 Firmware Upgrade to version 5269
    Version 5269 firmware for the Volkswagen RNS 510 and the Skoda Columbus has been released.
    Voice Control (requires microphone – see*Volkswagen RNS 510 Microphone Connection for voice control)
    NEW DAB+ Support (from 5xxx)
    NEW DAB Support (from 4xxx)
    NEW Radio Text (from 4xxx)
    NEW*Faster navigation and user interface
    NEW*Automatic illumination control
    NEW*Enhanced destination input
    NEW*hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
    NEW*Compass
    NEW*POI- see*Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
    NEW*Languages – Arabic, *Russian, Turkish and Polish
    Speed Limit Display
    Stability Improvements
    Faster Startup (from 2720 onwards)
    Display OPS and RVC at the same time
    SDHC 32 GB Support (HW04 and above)
    Display Off on extras tab
    Climatronic control if approriate climatronic fitted
    Clock display if RNS 510 swtiched off
    Excluded roads (under route options)
    GPS coordinates entry
    Additional adjustments for video
    Larger RVC screen with transparent menus at the side
    Units that can be upgraded include (still being compiled may not be 100%)
    All D and later versions.
    Download Firmware Upgrade
    Warning!*There is a remote chance of you ‘bricking’ the unit, this is a fraction of a percent but it could happen! The process takes around 60 minutes.
    Warning!*Users with cars MY07 and earlier may experience power drain issues after the upgrade. See the post “Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210,
    Kan man gå direkt från min gamla Firmware till denna, eller måste jag ta de som kommit ut emellan först?
    Under infon för Firmware 5269 står att alla version D och senare kan ha denna firmware...
    Men på den första infon står att man kan ta 5269?
    Please help me!
    Är jag rätt ute med 5269 eller helt fel?
    okt 2008
    soyd
    Örnsköldsvik
    Hej Jan,
    Du har en av de tidigaste revisionerna av RNS510 rev B, så senaste "orörd/unmodified" original firmwaren du kan köra är 150X. Men RNS510 scenen har lyckats att modifiera de senare/senaste firmwaren så att de lirar på de lite äldre enheterna. Du bör dock vara medveten om att den firmware du eventuellt kommer att ladda in är modifierad och där med är det en avsevärt större risk att det kan gå åt skogen, än om den vore orörd så satt säga. Mest troligt så lirar det utan problem, men du bör vara medveten om att risken för att bricka den finns ändå där...
    /mvh soyd
    jan 2008
    Evil E
    Sthlm
    Citat Ursprungligen postat av soyd Visa inlägg
    Hej Jan,
    /mvh soyd
    Tror även jag har den äldre varianten (Golf R -11), ska kolla mer exakt senare. Vad betyder "att bricka"? Irreparabel?
    Går det att uppdatera över flera steg, eller måste man köra varje uppdatering?
    Med Vänlig Hälsning, E
    dec 2011
    Luleå
    Citat Ursprungligen postat av Evil E Visa inlägg
    "Bricka" = den blir sten död och lika användbar som en tegelsten.
    jan 2008
    Evil E
    Sthlm
    Citat Ursprungligen postat av Merlinen Visa inlägg
    Makes sense! Tack!
    okt 2008
    soyd
    Örnsköldsvik
    Tjena Evil E,
    Jag tror dock att du bör ha en nyare revision än vad Faltdach har i sin. Men om du postar lite screens på från din enhet så kan vi nog lista ut vilken version du har
    Du behöver inte uppgradera i den ordning firmwaren är släppt, bara du vet att den du vill lägga in lirar så kan du gå direkt på den.
    /mvh soyd
    jan 2008
    Evil E
    Sthlm
    Tjena Evil E,
    /mvh soyd
    Kanon! Återkommer med lite screens inom kort!
    Gojz
    Namn:  IMG_20140417_115232.jpg
Visningar: 1345
Storlek:  160.2 KB
    Hur långt vågar jag uppdatera denna?
    jan 2008
    Evil E
    Sthlm
    Ehrmm... Tror jag har en riktigt gammal rutten version. Kommer ej längre än såhär. Finns ngt annat sätt att ta sig in i setupmenyn?
    Namn:  ImageUploadedByTapatalk1398093898.269829.jpg
Visningar: 1083
Storlek:  314.1 KB
    sep 2011
    Magnus kalin
    Evil
    Tror du behöver aktivera servicemenyn om du inte kommer längre ( obs har jag för mej)
    Vag-com(vcds) löser det
    jan 2008
    Evil E
    Sthlm
    Aha... Har ingen sån, kan de aktivera åt mig inne på VW månde tro? Eller kanske ngn här som skulle vlja hyra ut sin / hjälpa mig med uppdatering vis VagCom (någon sorts ersättning för mödan utgår givetvis, ett par öl el cash, välj själv)
    Jan Axelsson
    Jag lyckades låsa upp den "Hemliga Menyn# genom VCDS...
    Var inte så svårt när man hade tillgång till VCDS.
    Gör så här...
    Använd Vagcom / VCDS öppna kanal 37 - Navigation, gå in i anpassning och byt kanal 50 till 1 (blir 0).
    Sedan får du starta om din RNS.
    Sedan kan du komma åt den sk hemliga menyn genom att hålla inne SetUp knappen i ca 20sek..
    sep 2011
    Magnus kalin
    Jag aktiverade igång min med vcds också.
    Har du vägarna förbi jakan så har jag grejerna evil
    jan 2008
    Evil E
    Sthlm
    Citat Ursprungligen postat av Mange.k Visa inlägg
    Hyvens! Har dessvärre sällan det och har jag väl det så är tanten och lilltjejen med (IKEAlajnen) såattehh...
    Gojz
    Citat Ursprungligen postat av Gojz Visa inlägg
Visningar: 1345
Storlek:  160.2 KB
    Ingen med tips??.?
    jan 2008
    Evil E
    Sthlm
    Hello, skakar lite liv i detta skrangliga gamla skelett till tråd!
    Nån i sthlm centralt som har en vcds och skulle vilja hjälpa mig med detta? Har liksom inte blivit något av tills nu!
    Lars Höstner
    Sthlm
    Lägga i ny firmware kräver inte vcds.
    Eller vill du komma åt menyn? Lirar det inte Att du hållet in setup längre (typ jätte länge)?
    Jag höfta till på en firmware på min och det funka galant. Är på 5xxx nånting. Tid den senaste jag kunde hitta.
    Det fucka ur nån gång men det finna "fix" skivor att bränna ut om man får swl error.
    "Nav döden" är dock alltid närvarande.
    Varför vill du uppdatera?? Har du några buggar?
    Skickat från min dUmfån med Tapastalk
  1. Firmware RNS510?
    Av Weckis i forum VW-forum
    Svar: 16
    Senaste inlägg: 2014-02-18, 18:55
  2. Hur kan jag hitta uppgifter om min Golf?
    Av crossgolf i forum VW-forum
    Senaste inlägg: 2011-07-27, 20:27
  3. Svar: 0
    Senaste inlägg: 2010-07-25, 13:37
  4. Har jag rätt Bränslevåg i min gti 16v ?
    Av krillian i forum VW-forum
    Senaste inlägg: 2009-06-10, 19:42
  5. Svar: 3
    Senaste inlägg: 2008-03-17, 06:58
