2013-08-14, 21:40 #1ezitsujGäst
Guide: Uppdatering av RNS-310 till firmware 0351 eller 0357 för utökad blåtand
Tjena
Jag är moderator på Nordic Audi och har även reggat mig här nu när jag köpt en Golf 6 1.6 TDI till tanten
Bilen hade en RNS-310 med lite för gammal programvara för att installera en fiscon eller en 9w7 blåtandsenhet så jag satte fart med att forska reda på hur man uppdaterar
VW själv säger att det inte går, jag säger att de har fel
Här är guiden, på engelska, Skivorna finns att ladda ner på internet
Googla på : "Volkswagen / Skoda / Seat RNS 310 Firmware update" så bör ni hamna rätt
This torrent cotains 3 iso files that you can use to update your RNS-310 unit
According to volkswagen this should not be possible, but it is!
This new firmware activates the ability to control your bluetooth phone if you have a bluetooth interface,and it also adds bug fixes and navigation improvements
I made this torrent to keep this information avaiable to many people, read the original thread here:
http://gpsunderground.com/forum/volk...irmware-3.html
Read this carefully before you continue!
The update process takes about 60 minutes, so make sure that you have a healthy battery and turn all lights,ac etc off before you start
Its ok to use a CD-RW, but make sure you burn the image in imgburn at the slowest possible speed supported by your record device. I used TDK cd-rw's.
Different files should be used depending on what firmware you have in your unit!
To se your current version, press and hold "SETUP" and then click version
Different versions:
02xx
If you are on any 02xx firmware but NOT on 0235 (like 0212, 0227 etc) you should use this disc:
"RNS310-02xx to 0351.img"
Burn the disc, put it in to the drive and follow the instructions on screen, the update will take about 30-60 minutes depending on your current version
The device will reboot several times during the process.
It should look like this:
http://www.motor-talk.de/bilder/rns-...206034510.html
When the update is done, press SETUP again to make sure that you are on 0351.
(Optional) If you want to update to from 0351 0357 you can use this disc:
"Official Volkswagen 0335 or 0235.iso"
IMPORTANT! Only update to 0357 if you where on 02xx when you started this process, but NOT on 0235
!WARNING! , if you have updated from 0235 to 0351 using "RNS310 - 0235 to 0351.iso", do _NOT_ update to 0357 afterwards!, you may end up with a bricked device !WARNING!
The above warning is unconfirmed, so if you want to risk your device go head, but dont blaim me It MIGHT work but since the "RNS310 - 0235 to 0351.iso" is custom made, dont risk it. 0351 and 0357 is to my eyes identical in functionality
0235
If you are on 0235, please use this iso to update to 0351:
03xx
If you already are on a 03xx firmware when you start, use the "Official Volkswagen 0335 or 0235.iso" to update to 0357
OBS, vill tilllägga att jag inte tar något ansvar för om något går sönder när i använder denna metod.
Den fungerar, men används på egen risk!
Mvh MarcusSenast redigerad av ezitsuj den 2013-08-15 klockan 00:37.
2013-08-15, 12:35 #2
- Erik Cullberg
- 4569
- Alingsås
- 3 956
Välkommen, bra med nyttig information
2013-08-15, 13:58 #3
RCD 510 istället för 310 ?
Av quackpack i forum VW-forumSvar: 37Senaste inlägg: 2014-02-28, 10:14 -
RNS 510 - uppdatering
Av Gojz i forum VW-forumSvar: 0Senaste inlägg: 2013-08-13, 23:51 -
Nån som sitter på en Guide för Kofongare av Golf V
Av christian19 i forum VW-forumSvar: 4Senaste inlägg: 2009-01-24, 21:57
