Körde felsökning och hittade flera felkoder, hur åtgärda?
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
77-Telephone -- Status: Malfunction 0010
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P102230402
Coding: FDA37F46000E02002002
Shop #: WSC 05314 123 12345
VCID: 2F556B53BE00E759C75-807A
2 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0305
Revision: 13101005 Serial number: 0000475400
Coding: 0000B5
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 65F9C97B647C6D09FD9-8030
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001293120
Coding: 000090
1 Fault Found:
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 142063 km
Date: 2015.06.02
Time: 18:19:57
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 040 0166
Revision: 00000001 Serial number: VWZ1Z3K6360926
Coding: 0500040004
Shop #: WSC 05314 000 00000
VCID: 65F9C97B6C7C6D09FD9-8030
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
Date: 2015.06.02
Time: 22:56:19
00821 - Antenna 2 for Radio (R93)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 88
Mileage: 142075 km
Time Indication: 0
Date: 2015.06.02
Time: 22:56:19
03138 - Input AUX IN
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 89
Mileage: 142063 km
Time Indication: 0
Date: 2015.06.02
Time: 18:12:09
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H15 4217
Revision: 1B001001 Serial number: 00000000000000
Coding: 0A11000000010101
Shop #: WSC 03743 444 00001
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3C4F4C1FB7760CC1727-8069
7 Faults Found:
9455635 - Telephone Microphone
B1048 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 88
9457427 - Left audio channel for speech/telephone
B104F 13 [008] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 88
9457171 - Right audio channel for speech/telephone
B104E 13 [008] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 88
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
12718592 - Steering Column Control Module
U0212 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
0022 - Radio
U1066 00 [008] - No Communication
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
End-------------------------(Elapsed Time: 02:13)--------------------------
