Bytte CANBUS gateway fick följande felkoder (MK5 GTI)
Hej installerade min nya CANBUS gateway i kväll här, fick dock följande felkoder:
Bytte från: 1K0 907 530 K
Till: 3C0 907 530 Q
På en Golf GTI 2007 (Edition 30)
Några idéer ?
Kod:
Friday,17,May,2019,21:39:47:41854
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
Dealer/Shop Name: Volkswagen Sverige
Workshop Code: 031 45634 074342
VIN: XXXXXXXXXXXXXXXXX License Plate: XXXXXX
Mileage: 77220km Repair Order:
Chassis Type: 1K (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56
VIN: XXXXXXXXXXXXXXXXX Mileage: 77220km
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 L HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 02 3$30
Revision: 5BH16--- Serial number: VWZ7Z0F8230696
Coding: 0403004318070160
Shop #: WSC 00191 264 15243
VCID: 2F552DBBBEBE323274-807A
No fault code found.
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 01279 785 00200
VCID: 73DDE1CB121656D2D0-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70D7EEC763006DCA2D-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006464033
Coding: E58F8F2700041500471400001400000000097F075C0001
Shop #: WSC 00000 785 00200
VCID: 6CEFFAB74F28892A11-8038
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 271006 020 0501
Coding: 00038805
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 071206 020 0105
Coding: 00208933
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0XCHSA
Coding: 0013111
Shop #: WSC 01269 785 00200
VCID: 3D4907F364D2D0A2F6-8068
Subsystem 1 - Serial number: 6332MSME152C7C52H
Subsystem 2 - Serial number: 6342MSME15446947C
Subsystem 3 - Serial number: 6352QSME19771723E
Subsystem 4 - Serial number: 6362QSME1A642749L
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74DFE2D7171851EAC9-8020
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 863 HW: 1K6 920 863
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8230696
Coding: 0005103
Shop #: WSC 45634 031 74342
VCID: 6EEBF0BF79347B3A3F-803A
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3640P17520034B
Coding: E9801F06500202004000
2 Faults Found:
02638 - Enabling Steering Column Lock
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 9
Reset counter: 1
Mileage: 77217 km
Time Indication: 0
00474 - Control Module for Immobilizer
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 77221 km
Time Indication: 0
Address 25: Immobilizer
Cannot be reached
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
Component: RNS-MID H03 3970
Revision: AB001001 Serial number: --------------
Coding: 00010000010000100000
Shop #: WSC 01279 758 00200
VCID: 2F552DBB7EBE323274-807A
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0981
Coding: 0000052
VCID: 384716E74BF0F58A25-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 345F22D7579811EA09-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 00D802087F2D8405484A03E010CC
VCID: 78C7D6E70B70358AE5-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000104431
VCID: 2A633CAF855C571AA3-807E
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000052
VCID: 394113E370FAEC82DA-806C
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
End-------------------------(Elapsed Time: 01:40)--------------------------
Tack på förhand!
