13 bifogad(e) fil(er)
Polo generation 6 SUV T-Cross
1 bifogad(e) fil(er)
2019 VW T-Cross Small SUV Reveals More Of Its Design In Latest Spy Shots
VW has started testing prototypes of the upcoming T-Cross with significantly less camouflage on them, giving us a proper look on the boxy lines of the new small SUV.
Set to make its debut in October, the VW T-Cross test car pictured here tries to disguise itself in places as the bigger T-Roc, including the cladding on the bumpers and lights all around. According to official sketches, the final production version will feature square-shaped taillights connected with a light bar across the rear end.
The T-Cross will be VW’s fourth SUV in its European range and the most affordable of the lot, as it will slot beneath the existing T-Roc.
According to the company, the new VW baby SUV will be 4,107mm-long and 1,558mm-tall, which means it’s slightly larger than the Polo supermini. The two models are based on the same MQB A0 platform, with VW claiming that the T-Cross will offer a spacious interior and a class-leading luggage space of up to 455 liters.
Set to go against models like the Nissan Juke and the Renault Captur, the new VW T-Cross will be offered with three petrol and one diesel engine options. The first two petrol models will be powered by the company’s 1.0-liter TSI unit with 95PS and 115PS, while the third one will use the 1.5-liter TSI with 150PS. The single diesel TDI model will come with 95PS.
Transmission options will include both manual and dual-clutch automatic gearboxes. All models will be offered with front-wheel drive only.
VW will reveal the final production version of the T-Cross this October, with sales set to begin in Europe in spring of 2019.
https://www.carscoops.com/2018/08/20...est-spy-shots/
Bifogad fil 10184
Det där är T-Roc (Golf), inte T-Cross (Polo) :)
T-Cross
Någon som vet vilket datum den ska presenteras ? :confused:
Jag har på flera olika ställen läst Oktober 2018 men inget datum.
4 bifogad(e) fil(er)
"Min" T-Cross GT 1.0 TSI 85 kW (115 hk) 7 vxl DSG (V2X7K2AL) - hur ser "din" T-Cross ut? :)
Bifogad fil 10643
Bifogad fil 10644
Bifogad fil 10645
Bifogad fil 10646
