Kod:
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H03 0004
Revision: -------- Serial number: 90372KBM001WH
Coding: 0000FF
Shop #: WSC 06335 000 00000
VCID: 44875BE3C7DE633EFFF-8011
Component: E221 - MFL H02 0003
1 Fault Found:
00895 - Cruise Control Switch (E45)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 143548 km
Time Indication: 0
Date: 2014.06.14
Time: 12:44:08
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 D HW: 8K0 920 930 D
Component: KOMBIINSTR. H20 0255
Revision: 00100000 Serial number: CIY454TC9
Coding: 0315080002000008010000
Shop #: WSC 12345 123 12345
VCID: 2E53194B7952F96E39B-807B
No fault code found.
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G09B2684BA
Coding: 00CF07
Shop #: WSC 02391 823 56573
VCID: 50AF67B303A68F9E4B7-8005
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0125
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H15 0038
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009702295
Coding: 011C02204000410001
VCID: 458146E7CCE45A36E81-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0326
Revision: 00002001 Serial number: 0124388724
Coding: 011A0620003904400020013680000000
VCID: 810912F7184C3616149-80D4
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009683702
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000510162
Shop #: WSC 00000 000 00000
VCID: 34670B23977ED3BE4FF-8061
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 02145 785 00200
VCID: 387F3F134B1637DE637-806D
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H05 0310
Revision: 00000008 Serial number: AUZ5Z6I1319793
Coding: 05000482040185000159070000
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 98
Mileage: 143548 km
Time Indication: 0
Date: 2014.06.14
Time: 12:34:22
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102437278
Coding: 010C02204000210001
VCID: 428B5DFBDDCA6D0ECD3-8017
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102436300
No fault code found.-
Felet på 01 och 16 hänger mest troligt ihop med varandra.
Kontrollera som jag tidigare skrev att GRA (Farthållare) är aktiverat i motorstyrdonet.
Felet på 56 (Radio) brukar man få om man kodar fel och kodar att radion har AUX fast den inte har det.
Den ligger och övervakar AUX ingången på radion fastvden inte finns/är aktiv.
Koda bort AUX på radion och se vad som sker om du INTE har en AUX ingång i bilen.
Annars kan du strunta i den felkoden.
Skrivet på forumspringaren.
Har haft farthållare hela tiden och det har funkat tills jag bytte släpringen. Kollade 01 och farthållaren var aktiverad som den skulle.
Ang. aux så har jag det så det är nog inget att bry sig om.
Försöker också koda 77-telephone för multiratt genom denna kod 0011400 men den vill inte acceptera. Vet du kanske nått om den?
Det är antagligen så att jag ska kunna använda knappen med munnen på ratten om man ska kalla den det.
Kommer inte på nått annat för tillfället , förutom det jag skrivit.
